PUBG SCREEN IS SLIGHTLY VISIBLE OVER DISPLAY
  1. abilashmandal106
    Cupcake Jul 11, 2020
    abilashmandal106 , Jul 11, 2020 :
    hi team,
    i play pubg on my oneplus 6t. i have been noticing a thing, over white screen i have able to see pubg screen on my display, i can see the bag sybol, guns symbol. its slight, try it once, make a display of white screen and see the corners and bottom you can see pubg screen slightly.
    kindly look ok into this.
    thanks
    Vishrit_8746 likes this.
  2. drl431
    Marshmallow Jul 11, 2020
    drl431 , Jul 11, 2020 :
    Hi, no team here as you are posting on a user community forum. But what you see is called amoled screen burn-in. It can occur from displaying a static image, at maximum brightness, and for many hours per day over a number of months. You could just ignore it, otherwise the only fix is to replace the screen.
  3. Shivam_sakral
    Honeycomb Jul 12, 2020
    Shivam_sakral , via OnePlus 6T , Jul 12, 2020 :
    Does it cover under warrenty?
  4. SurajLoharia
    KitKat Jul 12, 2020
    Caomhin likes this.
  5. abilashmandal106
    Cupcake Jul 12, 2020
    JubaL_VW and drl431 like this.
  6. Shivam_sakral
    Honeycomb Jul 14, 2020
    abilashmandal106 likes this.
  7. Vishrit_8746
    Eclair Jul 15, 2020
    Vishrit_8746 , via OnePlus 6T , Jul 15, 2020 :
    Hello, Its a Screen Burn in it appears when we play PUBG or any Large games on more Brightness for a Long Time. I also used to play for 5 6 hours. Its on my phone also. Its an Amoled nature it doesnt cover against warranty.
  8. GeraltRivia
    Cupcake Jul 15, 2020
    GeraltRivia , via OnePlus 6T , Jul 15, 2020 :
    To solve this issue you have to replace your screen, but if the burn in is not bothering your day to day usage then just ignore it. And I would suggest avoid using your mobile on full brightness.
    Bintang12 likes this.
