PUBG stuck at "CHECKING FOR UPDATES"
  1. E1527095403958
    Cupcake Feb 10, 2019
    E1527095403958 , Feb 10, 2019 :
    i am using 1+6 .. after recent update, i am unable to open the pubg game . the game get stuck at checking for update page.. does anybody have this issue.. if anybdy knows how to resolve.. please let me know....
    M1557991782166 likes this.
  2. BicycleRay
    BicycleRay , Feb 10, 2019 :
    Try clearing cache in Settings/Apps & Notifications /See All and find Pubg. Clear just the cache and trying opening the game again.
  3. E1527095403958
    i tried those... but it doesnt work. only for the first time after installation it works.. after that if i close the app and try to open it again .. it gives the error. only if i re install it again i can open it but that too only for the first time
  4. Sharry7
    Ice Cream Sandwich Feb 10, 2019
    Sharry7 , Feb 10, 2019 :
    Have you tried pressing repair client button?
  5. E1527095403958
    yes... i tried. i doesnt help much.. i surfed it in internet and found there are many issues like this reported recently
  6. Neddard
    Lollipop Feb 10, 2019
    Neddard , Feb 10, 2019 :
    Are those reports limited to the OP6?
  7. M0h1t Sharma
    Gingerbread Feb 11, 2019
  8. E1527095403958
    Cupcake Feb 11, 2019
    E1527095403958 , Feb 11, 2019 :
    yes... some of the issues are from op6 user
  9. E1527095403958
    yes... but doesnt change anything much
  10. Neddard
    Lollipop Feb 11, 2019
    Neddard , Feb 11, 2019 :
    E1527095403958
    yes... some of the issues are from op6 user​
    Have you raised the issue with PUBG Support?
    Deactivated User likes this.
  11. E1527095403958
    yes i have raised. but first i want to make sure that this is not something setting related issue in my phone.. i found few solution on the internet. but all were involving VPN suport
  12. Lauantai
    Lauantai , Feb 11, 2019 :
    ...its not op6 issue.
    just use your mobile connection to dl. dont use public wifis or vpn.
  13. E1527095403958
    i tried with my mobile network and also from my personal wifi conection.. i dont find any change
  14. E1527095403958
  15. Lauantai
    try setting your connection to lte only
    *#*#4636#*#* - phone information
    and most of the time this happens through public wifi or vpn.
    if it does not work, you need to install it again.
  16. Abdurrahman1999
    Cupcake May 11, 2019
    Abdurrahman1999 , May 11, 2019 :
    I am also having the same problem on oneplus 6t i have done many things checking youtube for solution uninstaling game sending messages to the pubg mobile page and my internet is working fine can anyone tell me how to fix it plzzz
  17. Deactivated User
    May 11, 2019
    Artemus. and V1548675207101 like this.
  18. _DEDSEC_
    Jelly Bean May 11, 2019
    _DEDSEC_ , May 11, 2019 :
    It's probably a server probablem just wait it out.
    V1548675207101 and Artemus. like this.
  19. shadow4ever
    Eclair May 12, 2019
    shadow4ever , May 12, 2019 :
    The thing is the game of *PUBG Mobile* is not coded by Tencent. It's by some 3rd party.
    Also, in the meantime try Fortnite. It works like a charm.
    V1548675207101 likes this.
  20. M1557991782166
    Cupcake May 16, 2019
