77
Push Notification Issues
  1. wizard Ice Cream Sandwich Nov 25, 2016
    wizard, Nov 25, 2016 :
    Still dont get emails i have to keep rebooting my phone daily its a joke !
  2. paulhm81 Cupcake Nov 26, 2016
  3. Maxmeng Cupcake Nov 27, 2016
    Maxmeng, Nov 27, 2016 :
    Hi guys, just want to share i solved this issue by completely OFF-ing Developer option.
    Simply disabling doze and all other method in this thread didn't work/ work intermittently for me.
    A bit of a sacrifice but really saved me a lot of trouble(My colleague communicate in whatsapp)
    Hope it helped .
  4. Svetlisav Eclair Nov 28, 2016
    Svetlisav, Nov 28, 2016 :
    Hi, I am not sure I understood what you did snd how you solved the problem, could you be more specific please?
    Thanks!
  5. simonthomas Donut Nov 29, 2016
    simonthomas, Nov 29, 2016 :
    After running some tests (which most of us have already done) I've got this from OP Support...
    [​IMG]OnePlus Support
    We've forwarded this to our ROM Team and they are now working on a fix.
  6. Maxmeng Cupcake Nov 29, 2016
    Maxmeng, Nov 29, 2016 :
    Setting > Developer option
    off this mode like the picture above.
    It solved the whatsapp getting "killed" issue for me.
  7. Svetlisav Eclair Nov 30, 2016
    Svetlisav, Nov 30, 2016 :
    Did you set Doze mode off before off-ing entire dev mode?
  8. vrbljani Gingerbread Dec 1, 2016
  9. Hoon Han Man Cupcake Dec 1, 2016
    Hoon Han Man, Dec 1, 2016 :
    I have the same problem.
    Notifications only on limited apps, mainly whatsapp, facebook, gmail and a few games.
    But other apps such as Outlook (!) and others do not give notifications at all.
    Quite annoying, I've checked all permissions, but everything seems to be set up correctly.
  10. MODI3366 Cupcake Dec 1, 2016
  11. Svetlisav Eclair Dec 1, 2016
    Svetlisav, Dec 1, 2016 :
    I did have a Note 4, wanted to get myself Note 7 but then happened what happened. Note is definitely my cup of tea. With OP3 I have two major issues: notifications sync and camera stabilizator (if any object is moving forget about clear picture, burst mode doesn't help either). We'll see...
    vrbljani likes this.
  12. Svetlisav Eclair Dec 1, 2016
    Did you turn Doze off before disabling Dev mode? Although I have no probs with Whatsapp, Viber, but I do with K9, Instagram etc.
  13. vauyeung Donut Dec 5, 2016
    vauyeung, Dec 5, 2016 :
    I'm having this problem as well with my OP3, running Oxygen OS 3.2.8.
    Contacted OP support last week, have not heard back yet. My WhatsApp, BlueMail, Gmail all stop getting notifications after about 20 mins of idling. My instant messages are no longer remotely close to being "instant" anymore and this is very frustrating.
    I first noticed it on WhatsApp while using Web App of WhatsApp, it notifies me that my phone is disconnected from the network. At first I thought it was my cellular network but this result was consistent on WiFi. I even crossed checked on my colleague's OP3 which had the exact same issue running the exact same firmware.
    Seriously OnePlus support, do something.. This may be my first and last One Plus product.
    Custnam likes this.
  14. ajorsey Cupcake Dec 5, 2016
    ajorsey, Dec 5, 2016 :
    Make sure the apps that aren't pushing notifications are not being optimized under the battery settings.
  15. Svetlisav Eclair Dec 6, 2016
    Svetlisav, Dec 6, 2016 :
    Tried thar, didnt work.
  16. wizard Ice Cream Sandwich Dec 6, 2016
  17. snehmshah1991 Cupcake Dec 7, 2016
    snehmshah1991, Dec 7, 2016 :
    Quite annoying.. I am facing similar issue. If the app is not in recents list or locked to it, then there will be no notifications for apps such as instagram, news apps which pushes news updates as and when it happens.
    Please help if you find any solution to it.
    Thanks in advance
  18. Waka_Yama Honeycomb Dec 7, 2016
    Waka_Yama, Dec 7, 2016 :
    So for me at CB 8 no further problems. Even Gmail can now be white listed and works in my case
  19. G_Nasgul_Mustermann_NMJo Cupcake Dec 7, 2016
    G_Nasgul_Mustermann_NMJo, Dec 7, 2016 :
    this is quiet strange
  20. chakri4u Cupcake Dec 30, 2016
    chakri4u, Dec 30, 2016 :
    For me most of the apps slowly started move out of push notifications (even though they have notifications enabled) and they usually start again whenever I do a reboot. But now all of them are dead except whatsapp and few others.
    And now suddenly the stock messenger seems to be gone silent .. ocassionally it shows notifications if the messages are from persons. For messages from Banks or etc they never show up. Need to go into the app to read them.
    Tried this ADB fix but still the same :(
    Any more tips???
