77
Push Notification Issues
  1. purextc69
    Gingerbread Jun 21, 2016
    purextc69 , Jun 21, 2016 :
    Probably didn't ask very clearly...
    I understand that I would have to use your command line fix without root. My question is can you use that command line from within that apk application once it is installed on your phone? Or do you HAVE to do it through a PC?
  2. Graham Robertson
    Jun 21, 2016
    Graham Robertson , Jun 21, 2016 :
    If you have the delayed notifications issue, and have applied my adb shell command line fix,
    correctly, then this fixes the issue - 100%
    so if the issue still exists, go back and read my instructions again, and apply the fix.
    theone2416s likes this.
  3. purextc69
    Anyone tried the 3.1.3 non official "OTA" update on the phone to see if it is fixed in that also?
  4. Graham Robertson
    Jun 21, 2016
    The apk fix with root, places a properties page on your phone that allows you to adjust all of the doze mode settings on your phone, it is not for the pc.
  5. Adipekar
    Adipekar , Jun 21, 2016 :
    I've had the OnePlus Support twitter account "assure" me that they'll be taking a look at this issue. Let's hope for a quick OEM solution.
  6. purextc69
    I understand it isn't for the PC...
    Your fix (the command line) has to be run on the PC with your instructions.....
    Can you also run your command line (dumpsys deviceidle disable) in the application (apk) on the phone?
  7. Graham Robertson
    Jun 21, 2016
    Thanks @Adipekar
    @OnePlus
    you can contact me directly to discuss this issue and the fixes
    in greater detail if you so choose.
    Adipekar likes this.
  8. purextc69
    Good news i suppose. Make sure someone posts up if they fix it?
    Deactivated User likes this.
  9. Graham Robertson
    Jun 21, 2016
    there is no need to run the command line fix from the application for root, as it has the ability to disable doze mode
    from within the app property page..
    see: @Adipekar post:
    "So I tested the aforementioned Doze Mode Editor from XDA-Developers Forums and straight up turned off Doze. Phone idled over night, all notifications came in in a timely manner and battery drain over night was 2% (which is perfectly fine for me, as long as I get push notifications on a consistent basis)."
    EDIT it appears you can run the command: dumpsys deviceidle disable
    from within the app page. but as I am not rooted,
    I have not checked the results.
    purextc69 likes this.
  10. purextc69
  11. Graham Robertson
    Jun 21, 2016
  12. purextc69
    Link doesnt work... why use only if rooted? The first post on XDA says it will offer and adb command line if it finds no root.
    I am so confused! :(
  13. Randroid
    Cupcake Jun 21, 2016
    Randroid , Jun 21, 2016 :
    I can confirm this works without rooting your phone. I hardly ever completely reboot my phone, so I'm glad this is a short term fix.
  14. Graham Robertson
    Jun 21, 2016
    Thanks for confirming
  15. Graham Robertson
    Jun 21, 2016
    To save confusion just use my adb command line fix:
    Here:
    https://forums.oneplus.net/threads/push-notification-issues.451149/page-6#post-14987240
    very easy, and root permission is not required.
    the apk. app fix is quite complicated and technical/requires in depth knowledge
    of the Android system, wake states, and doze functions, and also requires root access permissions.
  16. Adipekar
    Dear all, please upvote/like this thread by clicking the up arrow next to the Thread Title on the top of the page. We need to keep gathering attention to this issue and don't want this to get lost in the hundreds of threads on here already. Thanks!
  17. Graham Robertson
    Jun 21, 2016
    Can it be "pinned" like a sticky?
    mods, can you answer?
    @SoniaB
  18. Adipekar
    Probably only the mods can do that
  19. Graham Robertson
    Jun 21, 2016
  20. purextc69
    I am stuck with waiting for the phone anyway - they wont cancel my order so it looks like I will have to cross my fingers that this gets sorted before i get it.
