13
Put Bullets Wireless in carrying pouch?
  1. Dhruv Weaver
    The Lab - OnePlus 7 Pro Reviewer Jun 13, 2018
    Dhruv Weaver , Jun 13, 2018 :
    Maybe this is a ridiculous question, but I have been struggling to figure out how to put these headphones in the included "case" without bending the wires in possibly damaging ways. Has anyone figured it out? It seems like it was an afterthought, and it's way too small to properly fit the earbuds. It could be that it's just not possible without (risking) breaking something.
    Thanks in advance for all of your comments. I also understand that not many people got to get their hands on one, so I don't expect a bunch of answers.
  2. Shuffler505
    Jelly Bean Jun 13, 2018
    Shuffler505 , Jun 13, 2018 :
    I've seen a few online reviews that detail the same issue; the pouch is a little small and there's a fear of damaging the Bullets when 'forcing' them in.
    Currently don't own a pair myself but looking forward to reading responses :)
    Keshav69, Alvie and Dhruv Weaver like this.
  3. meatandy
    Oreo Jun 13, 2018
    meatandy , Jun 13, 2018 :
    I was able to get them in the pouch , but I couldn't get the opening the close properly so it looks like it's doing
    the Mad Dog Vachon thing.
  4. Dhruv Weaver
    Yeah, I've seen a bit of it too. The headphones are really good for the money (coming from an audio enthusiast and OnePlus fan)... I just wish the case would make some sense.
    Keshav69, ShermCraig and Shuffler505 like this.
  5. Dhruv Weaver
    Lol, I can get mine partially inside, although my main concern with putting them in entirely, would be causing flexion damage to the wiring.
    Keshav69 and meatandy like this.
  6. meatandy
    Oreo Jun 13, 2018
  7. Dhruv Weaver
  8. Alvie
    The Lab - OnePlus 5T Reviewer Jun 13, 2018
    Alvie , Jun 13, 2018 :
    I don't think the wires will be damaged but you have to very wrap up the harder wire first and insert it with the battery modules very quickly before it unravels then insert the thinner wire part then the earphone part making sure the magnet hold them together.
    Keshav69, meatandy and Dhruv Weaver like this.
  9. Alvie
  10. Dhruv Weaver
    I'll give it a shot, but having experienced and heard horror stories about headphone cables getting bent a little too much, I'm a little wary.
    Keshav69, meatandy and Alvie like this.
  11. Alvie
    Sure, go ahead, just don't force it.
  12. meatandy
    Oreo Jun 13, 2018
    Coil them like so...
    With the earbuds dangling , put this portion into the pouch first and gently tuck the wires leading to the earplugs into the pouch.
  13. meatandy
    Oreo Jun 13, 2018
    Nope , picture above
  14. Dhruv Weaver
    Thanks man, I'll try it out. I'm assuming that this is what @Alvie was also recommending.
    meatandy likes this.
  15. meatandy
    Oreo Jun 13, 2018
    Like you said already, you may not want to do this several times a day or they are not going to last very long.
    Keshav69 and Dhruv Weaver like this.
  16. Dhruv Weaver
    Yeah, although this new method probably won't do much harm, as long as the parts where the cables connect to the batteries, controller, etc isn't under too much tension, it would probably be okay.
  17. meatandy
    Oreo Jun 13, 2018
    Dunnow and Dhruv Weaver like this.
  18. Dhruv Weaver
    Yes thanks. This thread should be pinned lol. Your guys' help has been fantastic. Cheers, all.
    Keshav69 and Dunnow like this.
  19. Dunnow
    The Lab - OnePlus 6 Reviewer Jun 13, 2018
    Dunnow , Jun 13, 2018 :
    that's one more loop than I did o.o
    will try tomorrow. i just leave them by the phone or in my neck anyway so... :p
  20. Dhruv Weaver
    Yeah, but for that occasion that you need to throw them in your bag, this method actually works really well. I'm quite frankly surprised that OnePlus doesn't have any instructions on this.
    Keshav69, ShermCraig and Dunnow like this.
