Put my 3T's motherboard in a donor 3T? Problems?
  1. Law_rence Cupcake Aug 12, 2019
    Law_rence, Aug 12, 2019 :
    My 3T was in a (stupid) accident which made the body bent a little and crack the screen. But it still boots. So I want to replace the screen and check what else might not be working. Also, I want acces to my data, but I can't because I can not use the screen... But I figured that pulling the motherboard out of my 3T and putting it in a donor 3T might be easier (no heating & glueing...) and give me a better (non bended) body.
    My question is now, will I run into issues when I place my 3T's motherboard with all my data into another, working secondhand 3T? Of course, I do not want to do a factory reset. Are there any device specific things that might cause problems? Can I put my 128GB motherboard into a 64GB model? Can I use a Oneplus 3 body?
    Secondly, I've also read that Oneplus 3 screens are not fully compatible with 3T bodies. They work but you loose off screen gestures and tap-on screen.
    Any tips are welcome.
  2. S1509801375025 Gingerbread Aug 14, 2019 at 1:00 PM
    S1509801375025, Aug 14, 2019 at 1:00 PM :
    I don't think this is gonna work. Nothing wromg I'm trying of course. But I guess since both 3 and 3t work on different soc... This task seems more on the negative side.
  3. Shashank H Gingerbread Aug 15, 2019 at 5:04 AM
    Shashank H, Aug 15, 2019 at 5:04 AM :
    I'm using OnePlus 3t 64 gb motherboard on my OnePlus 3 which was also 64gb i had to replace front camera and battery to get it working no problem with screen or gestures
    Praty_28 likes this.
