272
OP2 [Q&A] The Ultimate OnePlus 2 Guide - Solutions e.t.c.
  1. devayu.rastogi
    Cupcake Nov 14, 2017
    devayu.rastogi , Nov 14, 2017 :
    Hey guys,
    I've been using OnePlus 2 from past 2 years. I just recently bought a new type c cable (the flat one which needs replacement) which was working fine for me. But a very weird problem came up just 2 days back.
    I can't charge my phone now. The cable works fine with other adapters(i tried a Motorola adapter) and more so the adapter works great with other cables (tried charging Motorola g5) , but they don't work at all together
    I have to use the Motorola adapter and OnePlus cable to make it work.
    Plese help out.
  2. Lancelot_69
    Lollipop Nov 14, 2017
    Lancelot_69 , Nov 14, 2017 :
    It sucks, I had the same issue, bought 3 different cables un on worked good. Sorry I would tell you which one but it is a generic no name.
  3. braveheart14283
    Cupcake Sep 7, 2018
    braveheart14283 , Sep 7, 2018 :
    Hello Friends , I have OnePlus 2 ( oxygen OS 3.6.1) with JIO on my 1st sim slot . Many times the VOLTE icons disappears from the status bar although the signal is full on the sim and the data is working .After VOLTE icons disappears I cant make any call from the sim and I dont have any other choice than disabling the sim card and re enabling it to bring the VOLTE back which is quite frustrating . Any help on this ?
  4. kaihp
    Jelly Bean Sep 26, 2018
    kaihp , Sep 26, 2018 :
    No help. Device is officially EOL. If VoLTE is important enough for you, get a device that is in-support from the vendor.
  5. Vihan bhardwaj
    Cupcake Oct 2, 2018
  6. RaiXioN
    Eclair Oct 2, 2018
    RaiXioN , Oct 2, 2018 :
    It won't work and will most likely brick your device.
    Vihan bhardwaj likes this.
  7. Vihan bhardwaj
    Cupcake Oct 2, 2018
  8. Alvie
    The Lab - OnePlus 5T Reviewer Oct 2, 2018
    Alvie , Oct 2, 2018 :
    It will definitely brick your device, don't flash anything that isn't meant for your device.
    Also, if you need to ask questions like this, I wouldn't recommend flashing anything at all on your device.
    kaihp likes this.
  9. P1547574838276
    Cupcake Jan 15, 2019
  10. TaskerLover
    Ice Cream Sandwich Jan 15, 2019
    TaskerLover , Jan 15, 2019 :
    maybe uninstall camera updates, so it resets to the factory camera. have you tried that?
  11. P1547574838276
    Cupcake Jan 16, 2019
    P1547574838276 , Jan 16, 2019 :
    no i didnt ..let me try it thank u..
  12. G_Nairn_Comyn_Jvgm
    Cupcake Jun 11, 2019
