272
OP2 [Q&A] The Ultimate OnePlus 2 Guide - Solutions e.t.c.
  1. HKS08
    Froyo May 19, 2016
    HKS08 , May 19, 2016 :
    Hello Everyone,
    I recently bought a new Oneplus2 and was previously using OPO (rooted and tried various ROMS)
    I want to switch from OOS to CM for the customization/themes and look but don't want to lose out of LAF, (can live without FPS)
    I'm confused about flashing grarak's cm13 or hydrogen OS or are there any other stable builds with good battery life anyone can suggest.
    Note: getting very poor battery life since two on OP2, idle drain.
  2. Spannaa
    KitKat May 19, 2016
    Spannaa , May 19, 2016 :
    It is possible but very few adaptors work with the OnePlus 2.
    Yours sounds like it's one that doesn't.
  3. Hitesh More
    Cupcake May 19, 2016
  4. Sandharbh93
    Froyo May 19, 2016
    Sandharbh93 , May 19, 2016 :
    Does anyone know how to restrict background data on the Oneplus Two?? Im using OOS3 Beta and its not showing me the option to restrict the background data in the data usage menu.
  5. dhairya38
    dhairya38 , May 19, 2016 :
    Thanks. It was indeed a foreign object. Problem solved. Cheers.
  6. Shivam_Tomar
    Cupcake May 20, 2016
  7. Alin Devassy
    Eclair May 20, 2016
  8. Aj115
    Donut May 20, 2016
    Aj115 , May 20, 2016 :
    Does anyone have a solution for the maxxaudio issue, im running 2.2.1. The issue starts when streaming over bt into the car, its completely flat with distorted bass. Totally unlistenable. But through regular earphones it sounds incredible.
    Iv tried disbaling it, also tried making a call whilst playing music, apparently that resets the eq...but for me no difference. Also tried different players (using poweramp currently) but still getting the same distortion.
    I really want this to work, i play music everyday in the car and now my journey is unbareable.
  9. Sahil chandel11
  10. sahil_starrh
    Honeycomb May 21, 2016
    sahil_starrh , May 21, 2016 :
    Phonograph is great
  11. wampa3000
    Cupcake May 22, 2016
  12. sahil_starrh
    Honeycomb May 23, 2016
    sahil_starrh , May 23, 2016 :
    I just updated to the new beta 3.0.1, should I wait for my battery to hit 0 and die, then charge it to 100% without touching it? I heard that calibrates the battery? Or shall I just charge it from 5% to 95% like i always do...
  13. Maheshbujji
    Gingerbread May 24, 2016
    Maheshbujji , May 24, 2016 :
    My op2 to not connect to my pc... plz say anyone how to connect... im tired to copy video and pics from my pc to my op2....!
  14. itsbhanusharma
    Ice Cream Sandwich May 24, 2016
    itsbhanusharma , May 24, 2016 :
    Issue: USSD Codes Not Terminating
    Hardware/software: Software (OxygenOS 3.0/3/0/1 - Beta)
    Timeframe: Since Installing the Marshmallow OxygenOS ZIP
    Screenshot: Attached below
    Description: Whenever using interactive USSD codes on the Dialer,
    the Previous Pop-up won't go away as soon as an input is sent for the next one.
    Ultimate result: stacked up USSD pop up windows which Won't Go away unless Cancelled Manually.
    Tried So far: Clear Cache/Clear Data/Factory Data Reset.
    Nothing had fixed it so far.
  15. Alin Devassy
    Eclair May 24, 2016
  16. Alin Devassy
    Eclair May 24, 2016
    Alin Devassy , May 24, 2016 :
    How is the beta release?
  17. harrytipper
    Cupcake May 24, 2016
    harrytipper , May 24, 2016 :
    I've read the Q&A and tried to repair my OP2 with it, but I failed. Problem is: I wanted to try CM, but on the way to do so I accidentally wiped my internal storage as well. Now I can't find a way to get a ROM on the phone so the TWRP can flash it. I've heard about ADB sideload and stuff like that, but I haven't been able to figure it out. Could someone maybe help me with that?
  18. Alvie
    The Lab - OnePlus 5T Reviewer May 25, 2016
    Alvie , May 25, 2016 :
    You have to have your data on while you set the limits
  19. Alvie
    Go to settings, storage (and USB), click the options button, enable OTG
  20. Alvie
    Grarak's CM is very popular as well as Hydrogen OS 1.4 + debloater.
    Other ROMs include: Purity (based on CM), kingmercians ROM (H2OS), HalogenOS (alpha, based on CAF)
