272
OP2 [Q&A] The Ultimate OnePlus 2 Guide - Solutions e.t.c.
  1. Harsimransingh26
    Gingerbread Jun 19, 2016
  2. Alvie
    The Lab - OnePlus 5T Reviewer Jun 19, 2016
    Alvie , Jun 19, 2016 :
    No, it won't charge at dash charging speeds. It may work but at the same speeds as the normal OnePlus charger.
  3. rafael667
    Eclair Jun 20, 2016
    rafael667 , Jun 20, 2016 :
    when i rotate the phone i lose the connection of the wifi. this still happening after i updated to the oos 3. it's fully stock, without root.
    Anyone experiencing the same?
  4. oneplustwo4454
    Cupcake Jun 21, 2016
    oneplustwo4454 , Jun 21, 2016 :
    Good Job
    If i have rooted and unlocked my op2 without any back up can you please help me how can I go back to my previous stock mode
  5. aaron.hossain75
    Lollipop Jun 21, 2016
  6. Alvie
    The Lab - OnePlus 5T Reviewer Jun 21, 2016
    Waterdroid and aaron.hossain75 like this.
  7. Spannaa
    KitKat Jun 21, 2016
    Spannaa , Jun 21, 2016 :
    It's usually a moderator that thinks a thread is worthy of being pinned.
    Why?
    Alvie likes this.
  8. Alvie
    Alvie , Jun 21, 2016 :
    This seems very odd, have you tried clearing cache in recovery?
    Also, it may be due to a poor wifi signal - you may want to check that out too.
  9. Alvie
    Credit: TheUnlockr
    kaihp likes this.
  10. oneplustwo4454
    Alvie likes this.
  11. Alvie
    You're very welcome :)
  12. aaron.hossain75
    Alvie likes this.
  13. aaron.hossain75
    aaron.hossain75 , Jun 21, 2016 :
    I was wondering that's why and its a great thread INDEED! :)
    Alvie likes this.
  14. sarat
    Ice Cream Sandwich Jun 22, 2016
    sarat , Jun 22, 2016 :
    Hey alvie in my Oneplus two i unlocked my bootloader using command fastboot oem unlock.
    Later when i check the status of the bootloader using fastboot oem check-info
    Device tampered: false
    Device unlocked: true
    Device verified: false
    Charger screen enabled: false.
    Does it mean my bootloader is unlocked as when i check my phone after unlocking the bootloader it is showing 17gb used and all my apps and data are cleared though...
  15. sarat
    And alive when i try to flash recovery using fastboot it gets successful but when i try to boot into recovery using fastboot boot recovery.img it is giving me dtb not found option.
    Volume down and power button doesn't boot into recovery it's struck in Oneplus logo screen.
    I have looked online and found out dtb not found means recovery is corrupted. I have tried 3.0.2 and 2.7.0 versions from dl.twrp.me/oneplus2 but it's not booting into recovery...
    Any clue what should i be doing
  16. sarat
    Waiting for ur reply i have only hour to get my phone ready..
    Thanks
  17. Alvie
    The Lab - OnePlus 5T Reviewer Jun 22, 2016
    Alvie , Jun 22, 2016 :
    Yes, your bootloader is unlocked and your internal storage (e.g downloads, music, pictures, video etc) remains
    sarat likes this.
  18. Alvie
    You need to use a modified twrp such as this one: https://drive.google.com/open?id=0B_nisE3yeA4raHFlSldXOF9nU1E
    sarat likes this.
  19. sarat
  20. Alvie
    It didn't work for you so I am recommending the modified twrp
