272
OP2 [Q&A] The Ultimate OnePlus 2 Guide - Solutions e.t.c.
  1. sarat
    Ice Cream Sandwich Jun 22, 2016
    sarat , Jun 22, 2016 :
    Oh ok... Thanks mate... Will try it and let u know
    Alvie likes this.
  2. Alvie
    The Lab - OnePlus 5T Reviewer Jun 22, 2016
    Alvie , Jun 22, 2016 :
    You're welcome :)
  3. Spannaa
    KitKat Jun 22, 2016
    Spannaa , Jun 22, 2016 :
    If you're running OOS 3.0.2 then official TWRP 3.0.2-1 works.
    Alvie and sarat like this.
  4. Alvie
    The Lab - OnePlus 5T Reviewer Jun 23, 2016
    Alvie , Jun 23, 2016 :
    Did it work?
    sarat likes this.
  5. sarat
    Ice Cream Sandwich Jun 23, 2016
    sarat , Jun 23, 2016 :
    Yes..... The modified worked... Thank you...
  6. Alvie
    You're welcome :)
  7. gauravfgc
    Eclair Jun 23, 2016
    gauravfgc , Jun 23, 2016 :
    Today I have updating my opt to oxygen version 3.0.2. Now the photos that received in wtsup are not open in proper way when open it shows postal ticket size n blurred not cleared when same photo open in gallery no issue in photo. Please suggest how to fix this
  8. Alvie
    Did you delete the files from your phone?
    If you go to WhatsApp Settings>Chats>Chat backups, is there anything there?
  9. Vishnugops
    Froyo Jun 24, 2016
    Vishnugops , Jun 24, 2016 :
    My friend's oneplus 3 running oos 3.1 gives 5hrs 30mins SOT with a smaller battery and more powerful processor than my oneplus 2, while on the other hand my oneplus two running oos 3.0.2 gives 4hrs SOT.
    A bit disappointed with the software and tired of waiting for these updates.
  10. Alvie
    The Lab - OnePlus 5T Reviewer Jun 24, 2016
    Alvie , Jun 24, 2016 :
    Try going to Settings > Apps > Google Play Services and clear data and cache
    There are also other factors affecting SOT such as usage, apps installed, screen brightness, connectivity used etc (The OP3 has more efficient hardware also)
  11. Vishnugops
    Froyo Jun 25, 2016
    Vishnugops , Jun 25, 2016 :
    I don't find the clear data and cache in Google play services
  12. Alvie
    The Lab - OnePlus 5T Reviewer Jun 25, 2016
    Alvie , Jun 25, 2016 :
    Click storage on that screen that you screenshotted
  13. Hazieq_Zulnwr
    Donut Jun 25, 2016
    Hazieq_Zulnwr , Jun 25, 2016 :
    My opt need 7 hour to fully charge. Can anybody explain why. How to fix this? This happened after i update to oxygen3.0.2. Is this relate with the software issue?
  14. Alvie
    Try clearing the cache in recovery mode
  15. Vishnugops
    Froyo Jun 25, 2016
    Tha="Alvie, post: 15010499, member: 680253"]Click storage on that screen that you screenshotted[/QUOTE]
    Thank you. Just did it, let you know if it's any better :)
    Alvie likes this.
  16. andrew_oneplus
    Donut Jun 25, 2016
    andrew_oneplus , Jun 25, 2016 :
    Is this anywhere near normal?
    Night - no usage, lost nearly 20%:
    Screen-On Time is around 2h
    OOS 3.0.2, unrooted. Tried following:
    - clean install
    - clear cache via recovery
    - google play services clear data
    - turning off wifi, BT, sync etc
    - removing apps one by one
    Still loosing about 20% over night.
    Still SOT very low
    Phone usage is moderate, no games or videos. Mostly messaging, browsing
    Is my phone defective? What else would you suggest?
  17. drdjender
    Donut Jun 25, 2016
    drdjender , Jun 25, 2016 :
    Guy I essentially soft bricked my phone.. Touchscreen isn't working at all I flashed the wrong kernel on a rom and now that happens adb is tricky and I don't know many commands but I need to know how I can do a clean flash of a rom only through Adb like clear all the caches (maybe screen will work after) I've only managed to wipe the system (my old rom files and that didn't restore the touch) I've been thinking oxygen recovery (as its based on buttons I think) but I'd need to flash hybrid twrp and then lollipop firmware but I have no idea what the commands are for stuff like this help me out?
    Update: after flashing cyanogen recovery (as it uses buttons) I can load roms into the phone from its storage but once loaded the touchscreen still doesn't work...
    after a bit more tinkering I was able to get capacitive buttons back but the touch doesn't work D:
  18. Alvie
    The Lab - OnePlus 5T Reviewer Jun 26, 2016
    Alvie , Jun 26, 2016 :
    As you use two SIMs it makes sense for your SOT to be low, especially as one of the SIMs doesn't have a very strong connection in your screenshot. However, if it is losing 20% overnight, something is wrong and it looks like you have already tried everything. You may need to contact OnePlus support for further help and advice or so they can repair it if necessary
    andrew_oneplus likes this.
  19. Alvie
    If you can connect your phone to your PC in fastboot mode, try this:
    fastboot devices
    fastboot format userdata
    fastboot format cache
    fastboot reboot
    Then boot your phone into recovery mode and go to adb sideload
    (TWRP = advanced adb sideload)
    (Stock = install from USB)
    Then open a command window in the folder containing the ROM zip by holding shift and right clicking then choosing open a command window here.
    Type in:
    adb sideload nameofzip.zip
  20. Hazieq_Zulnwr
    Donut Jun 26, 2016
    Hazieq_Zulnwr , Jun 26, 2016 :
    I had done clearing the catche in recovery mode. But the result also same. It's take 4h to complete the charging from 40%. This is not normal.
