142
[Q&A] The Ultimate OnePlus 3 Guide - Solutions e.t.c.
  1. Alvie
    The Lab - OnePlus 5T Reviewer Jun 19, 2016
    #61
  2. ravikrak
    Gingerbread Jun 19, 2016
    ravikrak , Jun 19, 2016 :
    Not able to turn on my wifi hotspot.
    Even Shareit application struggling. Keep on saying restarting hotspot.
    Anyone has this problem?
    #62
  3. Alvie
    Alvie , Jun 19, 2016 :
    I asked a person on the Support live chat, here is the response I received:
    #63
  4. Alvie
    Check your APN settings:
    Settings > Wireless and Networks > SIM cards> SIM Card 1 Settings > APN
    Remove any duplicates or if there isn't any, remove the current one and enter it in again.
    You can find them by searching:
    (carrier name)(country) APN settings
    #64
  5. joshuaalex
    joshuaalex , Jun 19, 2016 :
    Anyone know if you can disable OIS or EIS? As I believe both is making my video too wobbly, without root please.
    #65
  6. Alvie
    I'm not sure if that is possible you could try using a different camera app.
    #66
  7. Naman Bhalla
    Recognized developer Recognized Developer Jun 19, 2016
    Naman Bhalla , Jun 19, 2016 :
    Thanks. I will unhide thread and file. But, still, weird why it wasn't otaed yet
    #67
    Alvie likes this.
  8. apisarenco
    #68
    Alvie likes this.
  9. Alvie
    I do not think that the OnePlus 3 supports MHL, you'll be able to use casting though. (Miracast)
    #69
  10. rayth77
    Froyo Jun 19, 2016
    #70
  11. Alvie
    #71
  12. Alvie
    Before they answered that, they said that the OTA's are distributed randomly, even though I told the person on the live chat that no-one had received that OTA.
    #72
    Naman Bhalla likes this.
  13. sumitvrma
    Donut Jun 19, 2016
    sumitvrma , Jun 19, 2016 :
    Hello All,
    I tried using Reliance Jio Sim (India) in my OP3 today but failed to get signal.
    Can someone help me for the same please?
    #73
  14. Alvie
    Go to Settings > Wireless & Networks> More > Mobile Networks > Access Point Names > +
    APN: jionet
    APN type: internet+mms
    APN protocol: WAP 2.0
    #74
  15. KeithTalent
    Cupcake Jun 19, 2016
    KeithTalent , Jun 19, 2016 :
    This is very handy, thanks for posting it. Quick, super noob question more about the new OS I suppose, but I cannot seem to find any way to change the lock screen on my OP3. The Lock Screen option from the settings menu, which I had on my OPO, is gone now and so I am stuck with the super ugly default weather and clock widgets on my OP3 lock screen. Anyone know how I can edit the lock screen?
    Thanks in advance!
    #75
  16. Alvie
    I don't think you can, the feature you had on your OPO was probably a CyanogenMod exclusive. You may be able to use an app such as Next Lockscreen from Microsoft.
    #76
  17. vanhoopstallion
    vanhoopstallion , Jun 19, 2016 :
    I'm trying yto return to stock after installing paranoid Android. I'm running twrp, downloaded the 3.1.2 zip. Wiping all partitions, flashing this OnePlus3Oxygen_16_OTA_008_all_1606122244_e0cfc5ffc8bf411a.zip but when I go to reboot after a successful flash twrp tells me no OS is installed. I can't boot, just loops.
    Help i want tl go back to stock OS!
    #77
  18. KeithTalent
    Ah I see, thanks Alvie. That is extremely obnoxious; I use lock screen widgets all the time! I will give that app a look, thank you very much for your help.
    #78
    Alvie likes this.
  19. Alvie
    Use at your own risk, I am not responsible if anything goes wrong.
    First of all, if ADB is not installed already do so here:
    Filename: adb-setup_1.4.3.exe
    Download this file: Credit @Snoop05
    https://drive.google.com/file/d/0B0MKgCbUM0itNVB1elljU2NPR0k/view
    Locate the file, right click and run as administrator.
    Press Y at each step:
    Once the drivers are installed, the setup window will close and ADB and Fastboot will work!
    Download and extract this file:
    https://drive.google.com/file/d/0B9a0ULZKQLQmS2ZNZDNtS3gzMFk/view
    Place the OnePlus3Oxygen_16_OTA_008_all_1606122244_e0cfc5ffc8bf411a.zip into the platform tools folder and rename OnePlus3Oxygen_16_OTA_008_all_1606122244_e0cfc5ffc8bf411a.zip to:
    Code:
    oxygenos.zip
    Make sure it is oxygenos.zip and not oxygenos.zip.zip
    On your phone, reboot into TWRP, select Advanced, select ADB Sideload. Connect to your computer via USB.
    On your computer, whilst still in the platform tools folder, Hold SHIFT AND Right Click, then
    Open a command window.
    type in:
    Code:
    adb devices
    to make sure it is recognised
    then type:
    Code:
    adb sideload oxygenos.zip
    @Naman Bhalla will this work? Thanks by the way for helping me and the rest of the community :)
    #79
  20. vanhoopstallion
    Thanks - that did the trick. I needed to do make the adb flash twice as the first time it was still the same issue, no OS installed. The 2nd time I didn't reboot straight after the flash via the reboot button, but instead returned to the main menu and rebooted to system from there. Not sure if that had anything to do with it, but it did the trick!
    cheers
    #80
    Alvie likes this.
