142
[Q&A] The Ultimate OnePlus 3 Guide - Solutions e.t.c.
  1. Chandan+one
    Eclair Nov 5, 2018
    Mohd Abubakar likes this.
  2. Chandan+one
    Eclair Nov 5, 2018
    Chandan+one , Nov 5, 2018 :
    as per that post yes it's free.
    Mohd Abubakar and dineshsp04 like this.
  3. Mohd Abubakar
    Froyo Nov 5, 2018
    Mohd Abubakar , Nov 5, 2018 :
    actually I just exchanged my mi a1 with OnePlus 3
  4. Alvie
    The Lab - OnePlus 5T Reviewer Nov 5, 2018
    Alvie , Nov 5, 2018 :
    Try contacting OnePlus support, they'll be able to answer this and sort out your problem
  5. Mohd Abubakar
    Froyo Nov 5, 2018
    I tried contacting them they said it depends on the condition of the phone, they'll check whether there were any liquid repairs done before or not. and when I asked them whether it's free or not, they told me that they don't know
  6. Alvie
    It should be free if there is no damage of your fault.
    ghostofcain likes this.
  7. G_Chandu_Mirdoddi_HtCU
    Cupcake Dec 21, 2018
  8. danouk
    Donut Jan 15, 2019
    danouk , Jan 15, 2019 :
    I second this please can you add this step about dealing with DM Verity into the official 3/3T how to root?
    For the OnePlus 6T guide the step seems to be side loading a zip file before installing a root app.
  9. danouk
    Donut Jan 15, 2019
    I think I found the relevant bit
  10. G_harshith_beeravolu_jFH
    Donut Feb 25, 2019
  11. TAPJEET
    Gingerbread Feb 25, 2019
    TAPJEET , Feb 25, 2019 :
    google it. btw go to rum type cmd
  12. G_harshith_beeravolu_jFH
    Donut Feb 25, 2019
  13. TAPJEET
    go to run type cmd
  14. Alvie
    The Lab - OnePlus 5T Reviewer Feb 25, 2019
    Alvie , Feb 25, 2019 :
    Command window and powershell are similar. If you have an option for powershell you should be able to use that as well.
  15. nielsdef
    Cupcake Mar 10, 2019
    nielsdef , Mar 10, 2019 :
    Hi all, I have some mayor issues with my oneplus3. Hopefully you can help.
    Six weeks ago my phone stopped detecting my headphones. Later the mic also stopped working.
    Back then I tried all kinds of stuff. The only thing that worked, was rooting my phone and deleting the dirac apps.
    Unfortunately the problem returned after the phone app crashed last week. To fix it I tried wiping everything off my phone and installing a custom ROM. But the problem is not fixed. Does anyone have any other suggestions?
    Thanks in advance.
  16. mort_
    Gingerbread Mar 10, 2019
  17. PTuT
    Jelly Bean Mar 10, 2019
    PTuT , Mar 10, 2019 :
    There us a hidden Engineering menu where you can find different hardware tests. Dial *#36446337# but be careful what you do there. Then go to 'Manual test' and then go to 'Headset in-out test'. There is s also 'mic test'. Good luck.
  18. O1553004527513
    Cupcake Mar 22, 2019
    O1553004527513 , Mar 22, 2019 :
    This is my os version, i am having problem with my op3, my phone is becoming hang when i am getting a voice call from any number and also from internet calls from messenger, imo, WhatsApp etc. And also i think having 4g network issues , now what i should need to do?
  19. F_Mateo_Bratanić_aDzP
    Froyo Apr 4, 2019
  20. PTuT
    Jelly Bean Apr 4, 2019
    PTuT , Apr 4, 2019 :
    Try to boot in safe mode and see if your problem persists. Good luck.
