142
[Q&A] The Ultimate OnePlus 3 Guide - Solutions e.t.c.
  1. Alvie
    The Lab - OnePlus 5T Reviewer Jun 21, 2016
    Alvie , Jun 21, 2016 :
    First of all, backup all of your important files as this will cause you to lose your apps and data.
    Then, install ADB and fastboot:
    Filename: adb-setup_1.4.3.exe
    Download this file: Credit @Snoop05
    https://drive.google.com/file/d/0B0MKgCbUM0itNVB1elljU2NPR0k/view
    Locate the file, right click and run as administrator.
    Press Y at each step:
    Once the drivers are installed, the setup window will close and ADB and Fastboot will work!
    Enable USB debugging on your phone:
    1) Enable USB debugging and OEM unlock
    Go to Settings>About Phone>Tap Build number 7 times.
    Go to Settings>Developer's Options>Enable USB debugging and accept warnings.
    Connect your phone to the computer in recovery mode (VOLUME DOWN + POWER), wipe data + cache, then Install from USB
    Create a new folder and download this ROM onto it: https://www.androidfilehost.com/?fid=24591020540821926
    Rename the ROM zip to oxygenos.zip (make sure it isn't oxygenos.zip.zip)
    Whilst you are still in that folder, Open a command window:
    For this you have to open a folder
    Hold shift and right click
    Choose Open a command window
    Once that is done type in:
    Code:
    adb devices
    to make sure your device is recognized.
    And then
    Code:
    adb sideload oxygenos.zip
  2. Alvie
    @Naman Bhalla, I'm not sure if this is fully correct as I do not know how to do a clean flash via ADB Sideload
  3. Naman Bhalla
    Recognized developer Recognized Developer Jun 21, 2016
    Naman Bhalla , Jun 21, 2016 :
    Your guide is wrong. You can't sideload in bootloader mode. You need to be in sideload section of the recovery. For stock recovery, it is Install from USB and for twrp it is adb sideload
    Alvie likes this.
  4. Alvie
    Thanks, how do you clean flash though?
  5. Naman Bhalla
    Wipe data and cache in recovery for stock recovery and everything except internal for twrp
    Alvie likes this.
  6. Alvie
    Thanks so much, I really appreciate it and once again I am sorry for bothering you. I believe I have fixed it now.
  7. Naman Bhalla
    No issues.I am here to help.Yes.Seems fine now
    Alvie likes this.
  8. Alvie
    Any issues or anything else that I have missed out? Let me know :)
    (This post is to everyone by the way)
  9. TassiloG
    Cupcake Jun 21, 2016
    TassiloG , Jun 21, 2016 :
    Heya,
    I dot know if this is the right thread for it, so please tell me where to post when its wrong.
    Got my Beautiful OP3 few days ago and I LOVE it.
    but I'm a bit concerned about the speakers.
    There is always a little static noise, kind of light buzzing.
    Its always the same low volume level, but when the volume goes low, the noise becomes very annoying.
    Is it due to bad speakers? A software bug? Tried it on Youtube, chrome vids and whatsapp.
    Any ideas? :)
  10. Alvie
    This sounds like EMI (electromagnetic interference) which is caused by signals interfering with each other.
    https://en.wikipedia.org/wiki/Electromagnetic_interference
    TassiloG likes this.
  11. F_Richard_Hogg_JUjS
    F_Richard_Hogg_JUjS , Jun 21, 2016 :
    Turns out I was just being impatient. Strava just takes an age to find sensors first time around. So as long as you install the ANT services from the Play Store, it all works a treat.
    Alvie likes this.
  12. TassiloG
    Tried it outside with airplane mode and at other locations, still the same, didnt have it with my old phone :eek:
  13. liver
    Eclair Jun 21, 2016
  14. Alvie
    No, that is a cyanogenmod exclusive feature
  15. Alvie
    How bad is it? A little noise is usually not a problem. And also, does it happen with headphones?
  16. njain2686
    Honeycomb Jun 22, 2016
    njain2686 , Jun 22, 2016 :
    You can set double tap on the home button to switch off the screen.
    Alvie likes this.
  17. Orange72
    Gingerbread Jun 22, 2016
    Orange72 , Jun 22, 2016 :
    Push notification issues:
    This is caused by Doze, a feature implemented in Android Marshmallow to ignore wakelocks.
    In order to disable it for certain apps do this:
    1) Go to Settings > Battery
    3) Click the three dots on the top right, and click Battery optimisation
    4) Click All apps
    5) Tap on apps that you always want notifications for, and click Don't optimise (e.g. email, Whatsapp etc)
    Unfortunately this doesn't seem to correct the issue.
  18. crysen
  19. ianwootz
    Eclair Jun 22, 2016
    ianwootz , Jun 22, 2016 :
    How i can sideload oxygenOs sir? I have a stock hydrogen os and stock recovery
  20. Pr0metheus2
    Donut Jun 22, 2016
    Pr0metheus2 , Jun 22, 2016 :
    This option is not built in, however on some other systems it works.
