213
[Q&A] The Ultimate OnePlus 5 Guide - Solutions e.t.c.
  1. ariharan04
    Cupcake Jun 26, 2017
    ariharan04 , Jun 26, 2017 :
    The fingerprint does not. work after restart but it starts working after put my security pin.. how to solve this..?
  2. antiquegamer
    Donut Jun 26, 2017
    antiquegamer , Jun 26, 2017 :
    That is by design. You have to input your pin when the phone reboot.
    JanhaviPawar_ and Alvie like this.
  3. JuliusZet
    Honeycomb Jun 26, 2017
    Alvie likes this.
  4. Lindsay
    Donut Jun 26, 2017
    Lindsay , Jun 26, 2017 :
    Is there a known problem with apps being able to access storage as I'm having problems with podcast apps (Podcast Addict and Beyondpod) and sending file attachments in Aquamail.
  5. Lindsay
    Donut Jun 26, 2017
  6. AndreasBechN123
    Donut Jun 26, 2017
  7. DinkoDes
    Ice Cream Sandwich Jun 26, 2017
  8. DinkoDes
    DinkoDes , Jun 26, 2017 :
    Ufff 3.1.1 TWRP does not stick after reboot.
    Next reboot to recovery I am back on stock recovery.
  9. Tama-Y
    Tama-Y , Jun 26, 2017 :
    I noticed that in the GPS Settings, the "Qualcomm iZat" option is no longer available. The specs on Qualcomm page verify that it is indeed within the chipset. Is there a hidden option or patch to enable that setting?
  10. ivivdim
    Gingerbread Jun 26, 2017
    ivivdim , Jun 26, 2017 :
    Not sure if it will help you but give it a try: find your router in list of used but not active routers (in WiFi settings of your phone) and use the option to forget it. Then scan again. Something other you can try is to change the chanel of your router.
  11. abechung
    abechung , Jun 26, 2017 :
    Hey guys, it's been a while since I've flashed anything, so I have a question regarding stock OOS (bootloader is locked and I'm not rooted fyi):
    I'm on OOS 4.5.2:
    How do I reflash back to 4.5.1? I'm currently experiencing some broken apps due to the apps not being able to detect stable network connection (ie: kakao talk won't get past verification via sms text for some reason. Also, swiftkey doesn't let me download themes cause of network issues).
    Let me know if you need additional info. Thanks!
  12. G_Alex_Slavila_pFXM
    G_Alex_Slavila_pFXM , Jun 26, 2017 :
    Hello guys , I have a problem, my Oneplus 5 doesn`t vibrate. I don`t know what to do. Anybody else has this problem ? I made the settings corectly, the alert slider it`s on top and i checked enable vibration . Thanks
  13. jferraz
    jferraz , Jun 26, 2017 :
    Please how can I schedule silent mode so I don't have to manually set it everyday using the switch? This is a feature on every android phone but I can't find it one the Op5
  14. G_Shahar_Yakir_zEvk
    Cupcake Jun 27, 2017
    G_Shahar_Yakir_zEvk , Jun 27, 2017 :
    Is anyone else facing a text smudge on the OP5 when scrolling vertically? (Can best be seen in text articles, etc. )
    It gives the feeling as if there's a slight text jump animation, which isn't pleasant.
    This is my first OP device, coming from a Nexus 5 on which I have not encountered this issue.
  15. noy
  16. yblegal
    Eclair Jun 27, 2017
    yblegal , Jun 27, 2017 :
    Can we not change the resolution in the stock camera app, or am I crazy?
  17. G_Alex_Slavila_pFXM
    G_Alex_Slavila_pFXM , Jun 27, 2017 :
    If I am not the only one, maybe it's a software problem. I hope!
  18. madhavdatt
    madhavdatt , Jun 27, 2017 :
    Does the oxygen 4.5.2 OTA update for One plus 5 consume more battery than earlier?
    Just a few hours ago, I updated the OS with the latest 36 mb update that had optimisations on Camera, network etc.
    Don't know about the changes, but I'm already experiencing a faster battery drain. Anyone else face the same?
  19. iharshal02
  20. yblegal
    Eclair Jun 27, 2017
    Seriously if you are going to ask this question 6 or 7 times, what do you think?
    Take a consensus. Read the marketing literature. It says it is supposed to stay cool. It does for most people. Are you a bot cooked up by Samsung or a competitor? Seems weird someone would need to ask so much...
