176
[Q&A] The Ultimate OnePlus 5 Guide - Solutions e.t.c.
  1. G_syed_ibrahim_iRRs Cupcake Jul 16, 2017
  2. fbsoft01 Cupcake Jul 16, 2017
    fbsoft01, Jul 16, 2017 :
    thanks i'll give it a try but, i was hoping to not have to install other software for this feature... A few code lines could have this issue, as the phone dial and ringing is already built, you just need to check if the option is on and then give a flash. Anyway thanks for the suggestion, i was hoping for a cleaner one from one+ :) It's a cool feature for noisy or non noisy environments.
  3. fbsoft01 Cupcake Jul 16, 2017
    I have a few more issues: I had noticed that with the NFC started and NfcTools in the background ( forgot to close it and i had used it 10 mins ago) the 3g/4g(can't tell if it's 3 or 4g, in settings it isn't written, and i really don't want to install another app to tell me this ... ) although good from the signal icon, the data transfer signal is very ... stingy... web pages would load at a rate of 3-10 kb/s ...once i turned the NFC off, the data rate ran smoothly at 100k/s and the webpages were loaded instantly. This happend on Vodafone RO
    And second... i had left my phone over night with 60+% battery life, in the morning i saw it was at 34%... with night mode activated and battery optimization turned on. When i took a look at what drained my battery, i saw that the wifi was the culprit, but... the drainage was only about 4%, but the graph showed all night activity... Did another test, and i turned on advanced optimization, and i lost over night 4% ( from 100% to 96% ) only... So why with the night mode activated and the normal optimization do i lose so much battery at night ? Can't it be done so that in the night time the wifi to turn on once an hour or so, i sleep, if ppl need to contact me they'll do it via Voice or SMS ? I find it so ... un_UserFriendly to turn on the advanced optimization at night , and try not to forget it in the morning so i can get the always on optimizations... and not lose to wifi so much battery
  4. DSP_MARCO Cupcake Jul 16, 2017
  5. Panshesi Cupcake Jul 16, 2017
    Panshesi, Jul 16, 2017 :
    Hello, i wanna know when One Plus 5 will no more be updated
    Thanks for reply :)
  6. yaparla15 Gingerbread Jul 16, 2017
    sudha1c likes this.
  7. Tokfan Froyo Jul 17, 2017
    Tokfan, Jul 17, 2017 :
    When onpleus 6T is out. ;)
  8. Panshesi Cupcake Jul 17, 2017
    Panshesi, Jul 17, 2017 :
    Okay... And when One Plus 6T will be out ?
  9. G3kko Cupcake Jul 17, 2017
    G3kko, Jul 17, 2017 :
    Does default(pre-installed) Clock app belong to OxygenOS or to Adroid?
  10. dhausman Cupcake Jul 17, 2017
    dhausman, Jul 17, 2017 :
    That depends on whether the OP5T or OP6 come with built-in crystal balls. I've been putting in feature requests for that since OPO but OP doesn't seem to have been paying attention.
  11. Darshitjain37@ Donut Jul 17, 2017
    Darshitjain37@, Jul 17, 2017 :
    Can you please tell me
    I am having an issue while I dial *#808# and I select production test line 5 and after pressing all the buttons on my OP5 it shows something written in Chinese language and the customer care executive said that after pressing all the buttons it will show you the temperature of your phone
    Should I replace my phone because I have 1 day left to apply for replacement???
    please help
  12. KongSothea Cupcake Jul 18, 2017
  13. biswajit_sahu7 Froyo Jul 18, 2017
    biswajit_sahu7, Jul 18, 2017 :
    It has EIS though....if you still have hands like wobbly hands get a tripod.
  14. Jitesh Saitawadekar KitKat Jul 18, 2017
    Jitesh Saitawadekar, Jul 18, 2017 :
    Thanks for your suggestion but i like phones which functions perfectly with imperfect humans i might have shaky hands but i bet even a low budget phones have OIS.
  15. biswajit_sahu7 Froyo Jul 18, 2017
    Brother it is a well known fact that OP5 lacks OIS...to know that you had to come here and get an answer and then decide whether to buy or not...too much curiosity I wonder !!!
  16. Jitesh Saitawadekar KitKat Jul 18, 2017
    biswajit_sahu7 and aris like this.
  17. abadiloveyou Honeycomb Jul 18, 2017
  18. G_Victor_Bratoiu_jweL Cupcake Jul 18, 2017
    lucci_x likes this.
  19. F_Vaibhav_Bhan_kvsO Cupcake Jul 18, 2017
  20. Alvie The Lab - OnePlus 5T Reviewer Jul 18, 2017
    Alvie, Jul 18, 2017 :
    The clock app is very similar to the Android one but with a few cosmetic changes and an option to have an alarm even when the phone is off.
