184
[Q&A] The Ultimate OnePlus 5 Guide - Solutions e.t.c.
  1. A. Ahdach Guest Nov 4, 2017
    A. Ahdach, Nov 4, 2017 :
    Tnx Lot
    Tnx a lot
  2. G_Ian_Bleach_HoEZ Cupcake Nov 6, 2017
  3. markus1766 Eclair Nov 12, 2017
  4. JnManso Eclair Nov 12, 2017
  5. G_Sudhakar_Reddy_WaXI Eclair Nov 19, 2017
  6. YUshaRani Eclair Nov 20, 2017
    YUshaRani, Nov 20, 2017 :
    There is a water splash proof according to the keynote from China. Is that true?
    Even I saw in youtube vedio's
  7. Alvie The Lab - OnePlus 5T Reviewer Nov 20, 2017
    Alvie, Nov 20, 2017 :
    It isn't certified to be water resistant but there have been some YouTubers that have tried putting it into water (for short periods of time albeit) and it still worked.
    However, I wouldn't try this and would recommend to keep the phone away from water if possible to avoid unnecessary damage.
  8. Alvie The Lab - OnePlus 5T Reviewer Nov 20, 2017
    markus1766 likes this.
  9. guitarboy0211 Honeycomb Nov 20, 2017
    guitarboy0211, Nov 20, 2017 :
    Just read a report that the oneplus 5 is gonna be phased out. Kinda obvious that it would since it was out of stock long ago everywhere except in India. What I wanna know if it would end up being obsolete and just get minor updates (I know it's getting Oreo) but what I mean is if it would get 'oneplus-made' software features.
  10. Alvie The Lab - OnePlus 5T Reviewer Nov 20, 2017
    As it is similar to the 5T, I think it will prolong the software update period as they can roll out together (as is the case with the 3 & 3T). Time will tell.
    guitarboy0211 likes this.
  11. SudhakarReddy9427 Froyo Nov 20, 2017
  12. Alvie The Lab - OnePlus 5T Reviewer Nov 21, 2017
    Alvie, Nov 21, 2017 :
    As far as I am aware, there haven't been any new ringtones recently and I don't think there will be any new ones soon.
  13. SudhakarReddy9427 Froyo Nov 21, 2017
    SudhakarReddy9427, Nov 21, 2017 :
    oh! Thanks for letting us know.
    Alvie likes this.
  14. A. Ahdach Guest Nov 21, 2017
    Alvie likes this.
  15. F_Siddhant_Wahane_uuWf Gingerbread Nov 21, 2017
    F_Siddhant_Wahane_uuWf, Nov 21, 2017 :
    Today first time, almost 3 months after the purchase, my op5 hanged! Though the issue seemed to solved after I restarted!
    The screen when it hanged! You can see no icons there
  16. turek Cupcake Dec 14, 2017
  17. AlbeitRomance61 Eclair Dec 28, 2017
  18. Alvie The Lab - OnePlus 5T Reviewer Dec 28, 2017
    Alvie, Dec 28, 2017 :
    Have you tried holding on to the app and seeing if there's an edit option (or holding on the dragging upwards)?
    I don't currently have access to a OP5 (I'm on holiday) but I'll check it out soon. If it is not there then you should probably submit it as a bug and/or use a different launcher (such as Nova).
  19. AlbeitRomance61 Eclair Dec 28, 2017
    AlbeitRomance61, Dec 28, 2017 :
    there's an edit option for label but that's per app and permanent. this means I'll have to go to each of my app, place them on home screen then edit their labels to blank for ever.
    this is not the option I am looking for. nougat had an ability to just hide labels for all apps in app drawer screen only
    let me try nova.
    Alvie likes this.
  20. AlbeitRomance61 Eclair Dec 31, 2017
    AlbeitRomance61, Dec 31, 2017 :
    Even when my device is locked, I can pull down the slider and have access to torch, location, mobile data etc. access means I can turn them on/off. take screenshots etc.
    I consider this a security issue as potential thief can turn off internet n location or worse power off my device.
    can this be disabled to not work until device is unlocked in OnePlus 5?
