176
[Q&A] The Ultimate OnePlus 5 Guide - Solutions e.t.c.
  1. AlbeitRomance61 Eclair Dec 31, 2017
    AlbeitRomance61, Dec 31, 2017 :
    Even when my device is locked, I can pull down the slider and have access to torch, location, mobile data etc. access means I can turn them on/off. take screenshots etc.
    I consider this a security issue as potential thief can turn off internet n location or worse power off my device.
    can this be disabled to not work until device is unlocked in OnePlus 5?
  2. Alvie The Lab - OnePlus 5T Reviewer Jan 1, 2018
    Alvie, Jan 1, 2018 :
    I use a paid security app, Cerberus, to do this. It offers many other benefits as well compared to Android Device Manager such as ability to turn data on/off via SMS and also take pictures after failed unlock attempts etc
    AlbeitRomance61 likes this.
  3. F_Arpit_Saxena_RiUp Cupcake Jan 5, 2018
    F_Arpit_Saxena_RiUp, Jan 5, 2018 :
    Hi Team,
    i daily used to closed my wifi while sleeping but the wifi is open automatically. One day i have seen it wifi is opening and closing automatically.
    My phone is also hang problems.And there is network drop down to.
    When i paste on 1+ communication he simply says to sell this Device. Is it easy to it? And it is right way to talk your customer?
  4. Alvie The Lab - OnePlus 5T Reviewer Jan 6, 2018
    Alvie, Jan 6, 2018 :
    Hi! Just to let you know I'm not a part of OnePlus (i.e. I do not work for them) so I am not a part of their 'team'. However, I would consider myself as a part of the community here.
    Have you tried enabling and/or disabling Smart WiFi switch?
    Settings > Wi-Fi > [​IMG] > Smart WiFi Switcher
    I would recommend to disable it because in my experience it doesn't work very well, but you should try and see if that makes any difference.
    Also, clear cache in recovery mode (this will not wipe any of your data.
    I don't understand why a OnePlus employee would say that, it doesn't make sense to me. Did you contact via https://oneplus.net/support ?
  5. G1508007967501 Eclair Jan 6, 2018
  6. Aashishnayak Eclair Jan 7, 2018
  7. MJ_Vikram KitKat Jan 7, 2018
    MJ_Vikram, Jan 7, 2018 :
    read the beta thread first page.. everything is given there.
  8. F_Arpit_Saxena_RiUp Cupcake Jan 9, 2018
    F_Arpit_Saxena_RiUp, Jan 9, 2018 :
    smart Wifi- scanner is already off but the issue is still happening..
    can you suggest if the issue is due to enable of scanning always available?
    currently i have disabled the scanning always available.Could you please help me out if this also not work?
  9. Rambabu Kella Cupcake Jan 13, 2018
  10. Alvie The Lab - OnePlus 5T Reviewer Jan 13, 2018
    Alvie, Jan 13, 2018 :
    I believe so
  11. MikeG247 Ice Cream Sandwich Jan 13, 2018
    MikeG247, Jan 13, 2018 :
    This is a user community, the person who told you to sell your device is just a user like you so don't pay any attention. There are no OnePlus staff on here listening to your complaints. You need to submit proper bug reports to OnePlus using the correct feedback channels.
    Alvie and Hydra Bob like this.
  12. S1513895611934 Cupcake Jan 16, 2018
    S1513895611934, Jan 16, 2018 :
    hello,
    I bought a oneplus 5 , 2 months ago...
    do you know if protection is applied originally on the lens (as on the screen)?
    It seems to me, but I can not take it off ...
  13. Alvie The Lab - OnePlus 5T Reviewer Jan 17, 2018
    Alvie, Jan 17, 2018 :
    The back camera doesn't have a protector on it. It is made of sapphire glass so it shouldn't scratch easily.
  14. Rajat 01 Donut Jan 17, 2018
  15. staycalm Froyo Jan 24, 2018
    staycalm, Jan 24, 2018 :
    I downgraded Oreo to 7.1.1 (Oxygen 4.5.8) and I can't connect to my Wi-Fi network. It says connecting but it doesn't connect and then after a couple of tries the network disappears and after a minute appears again. Also when I go to Settings->About->Status, the IP Adress is Unavailable and also the Bluetooth address..
  16. Alvie The Lab - OnePlus 5T Reviewer Jan 26, 2018
    Alvie, Jan 26, 2018 :
    Was it a clean flash or a dirty flash? If it was a dirty flash, make sure to do a clean flash otherwise you will likely come across a lot of bugs etc.
  17. staycalm Froyo Jan 26, 2018
    staycalm, Jan 26, 2018 :
    Nevermind, I managed to get Oreo working again. :)
    Alvie likes this.
  18. Xelerater Saad Cupcake Feb 6, 2018
    Xelerater Saad, Feb 6, 2018 :
    I want to know, how can I flash latest Official Stable Build 5.0.2, I am currently on Open Beta 5 which is based on Oreo as well, please guide I am new to OnePlus 5, bootloader is unlocked but everything is stock
    Thank you,
  19. Alvie The Lab - OnePlus 5T Reviewer Feb 6, 2018
    Alvie, Feb 6, 2018 :
    It will involve a clean flash so you'll lose all your data, make sure to backup everything.
    Firstly download the stock rom to your phone:
    http://otafsg.h2os.com/patch/amazon...5Oxygen_23_OTA_029_all_1801292040_d71af3d.zip
    Then shut down your phone, and reboot to recovery (power + vol down).
    Once there, choose English > Advanced > Wipe Data And Cache > Reset system setting > Yes
    It should say "Format success", once this happens choose, "done" (don't choose reboot).
    Navigate your way to Install from internal storage, find the 5.0.2 ROM file and flash it then reboot.
    Xelerater Saad likes this.
  20. Xelerater Saad Cupcake Feb 6, 2018
