50
[Q&A] The Ultimate OnePlus 5T Guide - Solutions e.t.c.
  1. choobe Cupcake Dec 23, 2017
    choobe, Dec 23, 2017 :
    Hi Alive, thanks for creating this thread!
    ive got a questions, i just got my lava red op5t
    how do i install OOS on my chinese OP5T?
    i found threads for oneplus3t but not the 5t
    could you point me to the right location?
    #41
  2. FlightTribe Froyo Dec 23, 2017
    FlightTribe, Dec 23, 2017 :
    I was getting 1.7 Amps when charging from 75% using the included dash charger and red cable.
    Maybe it goes higher when charging from a lower battery percentage?
    I dunno....
    #42
  3. J1514039723328 Cupcake Dec 23, 2017
    #43
  4. Joniboi Cupcake Dec 24, 2017
    Joniboi, Dec 24, 2017 :
    Do everyone have problems with snapchat zoom? Does oreo update fix it or not? Is it android wide or just oneplus 5t thing? You have to get pictures from gallery if you want to send pictures to someone throught snapchat, the snap thing is un-usable because the quality of picture is crap and zoomed in
    #44
  5. Alvie The Lab - OnePlus 5T Reviewer Dec 25, 2017
    Alvie, Dec 25, 2017 :
    It should be around 1A to 1.5A (depending on the level of charge it has at the time). It's probably down to how Quick Chargers work. They're meant to act as normal chargers for phones that don't have QC built-in.
    #45
    robinsc likes this.
  6. Alvie The Lab - OnePlus 5T Reviewer Dec 25, 2017
    #46
  7. Alvie The Lab - OnePlus 5T Reviewer Dec 25, 2017
    #47
  8. robinsc Gingerbread Dec 25, 2017
    robinsc, Dec 25, 2017 :
    at 4% charge I saw values as high as 1.3 amp but that was the highest I saw
    #48
  9. robinsc Gingerbread Dec 25, 2017
    given that OnePlus has Qualcomm chips it would be awesome if a future model supported both dash charge and quick charge though I believe there are licensing costs for quick charge.
    #49
    Alvie likes this.
  10. hilwood Cupcake Dec 25, 2017
    #50
  11. Alvie The Lab - OnePlus 5T Reviewer Dec 25, 2017
    That makes sense, the maximum it can do is 2A but the adapter probably doesn't actually go above ~1.8A and there's also a constant discharge of ~0.4mA so altogether it would probably around about that.
    #51
  12. FlightTribe Froyo Dec 26, 2017
    FlightTribe, Dec 26, 2017 :
    I might be reading what the Ampere app says wrong, but it was showing 2700 ma the other day.
    That can't be right? 2.7amps?
    To be fair, it was charging pretty fast :D
    #52
  13. B1513928799289 Donut Dec 29, 2017
    B1513928799289, Dec 29, 2017 :
    i am facing an issue with wifi and mobile data
    as i have turn off wifi but some time it automatically turns on checks for the connection while my mobile data is turned on
    #53
  14. B1513928799289 Donut Dec 29, 2017
    #54
  15. Alvie The Lab - OnePlus 5T Reviewer Dec 29, 2017
    Alvie, Dec 29, 2017 :
    That can be right, depends on the percentage at that point and also if anything else is using the battery at the same time. When it gets closer to full charge, the charge rate starts slowing down.
    #55
  16. Alvie The Lab - OnePlus 5T Reviewer Dec 29, 2017
    I usually just charge overnight regardless of percentage etc.
    Some people recommend charging between 20% to 80%, some people used to say fully discharge and full recharge. And others say do little top ups throughout the day.
    Honestly, it probably doesn't matter much however you charge because battery technology and charging technology have gotten to points where it is designed to expect a lot of different use cases so it works fine whichever way you do it. That said, the latest from what I have read is that you should try to keep it between 50% to 80% with short top ups throughout the day.
    #56
    B1513928799289 likes this.
  17. NewCorn Gingerbread Dec 31, 2017
    NewCorn, Dec 31, 2017 :
    One T in Ultimate.
    #57
    Alvie likes this.
  18. robinsc Gingerbread Dec 31, 2017
    robinsc, Dec 31, 2017 :
    on my oem dash charger I get around 2.6 amps. Its fun to look at as it actually drops down to 0 and then gradually builds up to 2.6 from zero - so I guess that's how dash charge works every time.sadly oneplus own dash chargers will not charge if you have a power meter on the line because of the proprietary chips they use I suppose.
    #58
  19. psycholyzern Eclair Jan 1, 2018
    psycholyzern, Jan 1, 2018 :
    Why in my country, rooting will void the warranty?
    #59
  20. Alvie The Lab - OnePlus 5T Reviewer Jan 1, 2018
    Alvie, Jan 1, 2018 :
    If you bought it from OnePlus it shouldn't void the warranty. What country are you in?
    #60
