78
[Q&A] The Ultimate OnePlus 5T Guide - Solutions e.t.c.
  1. Chirostavros Froyo May 16, 2018
    Chirostavros, May 16, 2018 :
    Mate its a brand new Phone with 2 months of use. The battery lasts about 3 days
  2. SuperSkyHawk Donut May 19, 2018
    SuperSkyHawk, May 19, 2018 :
    recently I also encountered this. After clear cache, it was good for a while, then the issue came again.
  3. leakingh Cupcake May 20, 2018
  4. B_Purna_Chandu Froyo May 20, 2018
    B_Purna_Chandu, May 20, 2018 :
    maybe they removed this feature...
  5. Kytharsis Lollipop May 20, 2018
    Kytharsis, May 20, 2018 :
    Nope, it's still there.
  6. B_Purna_Chandu Froyo May 20, 2018
  7. Kytharsis Lollipop May 20, 2018
    Settings > Display > Ambient display > enable New notifications. Done.
    B_Purna_Chandu and Alvie like this.
  8. Alvie The Lab - OnePlus 5T Reviewer May 20, 2018
    Alvie, May 20, 2018 :
    Brand new phones can still have defects, it's rare but possible. I recommend you talk to OnePlus support about this
    Kytharsis likes this.
  9. B_Purna_Chandu Froyo May 20, 2018
    its working..thank you. Till now i though that option will make entire screen will turn on... thank u buddy
    Alvie and Kytharsis like this.
  10. moatazjasper Cupcake May 22, 2018
    moatazjasper, May 22, 2018 :
    Hello,
    So, I want to ask my fellow OnePlus 5T users about their day to day battery life experience. Basically, I have 2 sims installed, network data enabled 18 hours a day, no wifi, minimum usage of GPS (10 minutes or something), and almost no usage of Bluetooth. Screen brightness at a around 15%. I use my phone the the usual social media chatting, aimless browsing and netflix. And one of my biggest battery hogs is the alarm (one alarm every 5 minutes for 2 hours witb vibration on and highest alarm volume).
    Normally, I plug-in my phone to give it some juice in the morning to 80%, plug it again before leaving work to pump it up to +70%, then plug it in again before sleeping to reach the 80 or 90% threshold.
    My battery usage is now around 15% an hour while watching Netflix.
    So, is there anyone who is with the same pattern as I am who can tell me about their battery experience and whether my readings are normal?
  11. outpin Honeycomb May 22, 2018
    outpin, May 22, 2018 :
    Your readings are normal. I stopped looking for my SOT anyway. The dash charging feature is a beast.
  12. Architech88 Cupcake Jun 16, 2018
    Architech88, Jun 16, 2018 :
    Im having real trouble getting fastboot to recognize my device when trying to unlock bootloader. I have SO MANY drivers installed now but it still doesnt work.
    I'm using OnePlus 5t using android version 8.1.0 and oxygen os version 5.1.2.
    I just want to root my phone and have been rying on and off for weeks and I always get stuck at this point and NOTHING is working.
  13. Kytharsis Lollipop Jun 16, 2018
    Kytharsis, Jun 16, 2018 :
    Do you have the OP drivers and ADB properly installed?
  14. Nayanika Nagasree Froyo Jun 18, 2018
    Nayanika Nagasree, Jun 18, 2018 :
    I'm a noob and trying to catch up on rooting before rooting. Will there be any problems on rooting? Like I've read somewhere that Maps and some other apps doesn't work. Is it true?
    And If I want to unroot my phone, Is it possible? If yes, How?
  15. G_Devopratim_Biswas_YvOM Honeycomb Jun 18, 2018
    G_Devopratim_Biswas_YvOM, Jun 18, 2018 :
    There are no issues. Recently rooted my OP5. As the susbtratum was not working properly, so I reversed it back to stock. There are no issues or drawbacks. Just the thing that when you have your bootloader unlocked, you need to download the full rom when an OTA rolls out. Hope this helped.
    Nayanika Nagasree likes this.
  16. G_Devopratim_Biswas_YvOM Honeycomb Jun 18, 2018
    Unrooted by installing stock recovery and stock OS, then went to fastboot and typed the locking command. I think it is fastboot flashing lock. The data gets wiped each time you lock or unlock.
  17. Nayanika Nagasree Froyo Jun 18, 2018
    Thanks!
  18. Prashant Kudale Eclair Jul 12, 2018
  19. Guru0277 Froyo Jul 12, 2018
    Guru0277, Jul 12, 2018 :
    You have to just copy it ... no else .. ir used third party calculater apps like All in one calculater
    Prashant Kudale likes this.
  20. K1531734122474 Donut Jul 16, 2018
    K1531734122474, Jul 16, 2018 :
    I recently purchased ONEPLUS 5T. It came with preinstalled Android 7.1 and I chose to update the software by going into settings. The update size was 1650 MB and the download took 1.8 GB of my data plan. However, after downloading, my phone have a notification that the update had failed. Can someone please help me regarding this?
