112
OP6
[Q&A] The Ultimate OnePlus 6 Guide - Solutions e.t.c.
  1. G_mukesh_kommuri_ Cupcake Oct 13, 2018
  2. Kytharsis Lollipop Oct 13, 2018
    Kytharsis, Oct 13, 2018 :
    You have the option of using the power button to instantly lock too.
    G_mukesh_kommuri_ likes this.
  3. G_mukesh_kommuri_ Cupcake Oct 13, 2018
  4. Kytharsis Lollipop Oct 13, 2018
    That's really your only options that I know of.
  5. Syedshakir.83 Cupcake Oct 13, 2018
    Syedshakir.83, Oct 13, 2018 :
    Hi team, in on plus 6T , some time the Amazon App will work and sometime may not.when I click on app it won't open ,any solution ??
  6. G_mukesh_kommuri_ Cupcake Oct 13, 2018
    G_mukesh_kommuri_, Oct 13, 2018 :
    hi my mobile is taking 2 mts for automatic screen lock even though i gave 5 seconds sleep time can any one help me in this
  7. U1539502090903 Cupcake Oct 14, 2018
  8. J1539320506238 Cupcake Oct 15, 2018
    J1539320506238, Oct 15, 2018 :
    My Op 6 is heating while charging ... And it shows a purple tint while scrolling down the settings... Is it a defective peice ..Should I be return it?
  9. ARUN V NAIR Donut Oct 17, 2018
    ARUN V NAIR, Oct 17, 2018 :
    after the beta update my brightness adjustment has became a serious issue . before the update .i only had to 25% of the screen brightness and everything was clearly visible . in the latest update by putting 50% brightmess also makes a dull ness most of the time ..mainly when using in sunlight ...in sunlight i have to put full brightness to see things ...battery drain has also been incresed
    T1539963101036 likes this.
  10. W1533651272758 Cupcake Oct 19, 2018
  11. P1536715375725 Cupcake Oct 19, 2018
  12. T1539963101036 Cupcake Oct 19, 2018
  13. E1538232084253 Cupcake Oct 22, 2018
    E1538232084253, Oct 22, 2018 :
    when i swith the both sim for 4g its doesn't work.But 1 sim is jio i can't use both sim 4g because 4g is necessary for jio.When i swith my Airtel to 4g its network gone.Calls not connecting properly.Volte doesn't show,both sim doesn't not work for 4g.11th day of phone in hand.This is oneplus,the premium segment of phone?..if yes than i Ashmed to waste my money on it.
  14. G1540643881822 Cupcake Oct 27, 2018
    G1540643881822, Oct 27, 2018 :
    How do i report software bugs? Hi, 1st time OP owner here!
    I noticed that whenever my dialled calls go to voicemail, the (red) 'end call' button become unresponsive. I had to minimise the page and bring it up again and somehow it then works as normal.
    I found another one with Spotify and its notification bar. At times when i finish listening to spotify, sometimes i remove the said bar but it randomly pops up again and its becoming tiresome.
    Im on 6 and running the latest software 9.0.1
  15. ujwal p s Cupcake Oct 27, 2018
    ujwal p s, Oct 27, 2018 :
    My phone produces notification sound without any actual notifications... it's a kind of aanoying thing for me....can anyone help me to fix it
    Adityans97 likes this.
  16. U1539533132026 Cupcake Oct 29, 2018
  17. Sanketshejwal Donut Oct 29, 2018
    Sanketshejwal, Oct 29, 2018 :
    I'm facing a weird problem. My phone is using a lot of ram almost 7gb of the available 8gb. This is leading to frequent reloading of apps and different web pages. Anyone facing this issue?
  18. kaihp Jelly Bean Oct 29, 2018
    kaihp, Oct 29, 2018 :
    Which OS version are you running? Check which apps are hogging memory (could be browser or facebook).
    I got about 1.5GB RAM left, and I haven't rebooted for more than 3 weeks. I'm on OOS v9.0
  19. sambhab24 Cupcake Oct 29, 2018
    sambhab24, Oct 29, 2018 :
    I found Android p update bug in camera category as it significantly reduced the quality of LOW LIGHT PHOTOS with lots of noises.
    please fix this bug.
  20. T1527155441250 Cupcake Oct 30, 2018
    T1527155441250, Oct 30, 2018 :
    hello.... I purchased one plus 6 in June ..and when I compare my phone pictures with other one plus6 owners ...mine pictures look very dull and the dealer is not agreed on this .. please guide what to do?
