102
[Q&A] The Ultimate OnePlus 6 Guide - Solutions e.t.c.
  1. Kytharsis Lollipop Dec 9, 2018
    Kytharsis, Dec 9, 2018 :
    I assume you're from China... you guys get HydrogenOS. OxygenOS is for the international markets outside of China.
  2. GMitra Froyo Dec 9, 2018
    GMitra, Dec 9, 2018 :
    Can onePlus use the AI capability of snapdragon 845 chipset in onePlus 6, to better optimize the phone, manage RAM and the OnePlus 6 a better performing device
  3. Alvie The Lab - OnePlus 5T Reviewer Dec 9, 2018
    Alvie, Dec 9, 2018 :
    Contact OnePlus support, they'll be able to help you better with this.
    ArtiomCiobanu likes this.
  4. Alvie The Lab - OnePlus 5T Reviewer Dec 9, 2018
    Anything that is included with Android P that uses AI featutrs probably utilised the AI engine.
  5. V1527445199335 Donut Dec 13, 2018
  6. SolarEclipse KitKat Dec 13, 2018
    SolarEclipse, Dec 13, 2018 :
    Take one of you SIMs out and see if the notification goes away. If it doesn't try the other one.
    Kytharsis likes this.
  7. nikhil_thakur_0604 Cupcake Dec 14, 2018
    nikhil_thakur_0604, Dec 14, 2018 :
    Since last one month I experience that battery discharge quickly as compared to previous month's. Previously 100% battery stay for full day, almost 70% in evening 8pm after use of 12hrs. But now 2 time charging is required for same.
    Already format my phone to avoid use of unnecessary app. This helps me 2-3 days only. Still facing the same problem.
  8. Kytharsis Lollipop Dec 14, 2018
    Kytharsis, Dec 14, 2018 :
    How far are you letting it drop when you have to charge it the first of "2 time"?
  9. Robert_Schel Cupcake Dec 14, 2018
    Robert_Schel, Dec 14, 2018 :
    Camera audio problem; when recoring a video with the rear camera, everything is fine. But when using the front camera, the audio sounds weird and choppy, like there is some extreme noise reduction. All other apps (like snapchat and instagram) all have this same problem but with both rear and front camera. Even tried flashing it again with the msmdownloadtool, didn't solve it... does anybody have suggestions?
  10. nikhil_thakur_0604 Cupcake Dec 14, 2018
  11. Kytharsis Lollipop Dec 14, 2018
    That... doesn't answer my question.
  12. deepakpanwar_ Cupcake Dec 14, 2018
    deepakpanwar_, Dec 14, 2018 :
    hii I'm facing a problem with my OnePlus 6 ..
    when i connect my charger to device it charges quickly till 71% then it stops charging but in the battery indicator the bolt sign is still there and when I checked in the settings and battery it shows plugged in can't charge right now..
    is it a problem or is it normal? plz help
  13. Kytharsis Lollipop Dec 14, 2018
    Is there any errors it's giving?
  14. R1544794375115 Cupcake Dec 15, 2018
  15. nikhil_thakur_0604 Cupcake Dec 15, 2018
  16. macerg Eclair Dec 16, 2018
  17. Alvie The Lab - OnePlus 5T Reviewer Dec 16, 2018
    Alvie, Dec 16, 2018 :
    Yes. After rooting you will have to enable Magisk Hide
    Kytharsis and macerg like this.
  18. D1545000383503 Cupcake Dec 16, 2018
    D1545000383503, Dec 16, 2018 :
    Bought a oneplus 6 recently. The picture quality is great no doubt. But when I press the button to take the picture there is a lag of atleast a second or maybe half a second in taking the picture. This results in blurry pictures. Is there an expected fix by oneplus coming soon.?
  19. Kytharsis Lollipop Dec 17, 2018
    Kytharsis, Dec 17, 2018 :
    Keep your hand steady for a second longer while it processes the photo and you won't have this problem. It happens on every single phone.
    SolarEclipse and Alvie like this.
  20. D1545000383503 Cupcake Dec 17, 2018
    D1545000383503, Dec 17, 2018 :
    I dont think that is a fact
    On my galaxy s8 it was instant touch and boom and even on the modded gcam app that m using on oneplus its the same
