102
[Q&A] The Ultimate OnePlus 6 Guide - Solutions e.t.c.
  1. R1545041441860 Cupcake Dec 17, 2018
  2. R1545041441860 Cupcake Dec 17, 2018
  3. Kytharsis Lollipop Dec 17, 2018
    Kytharsis, Dec 17, 2018 :
    Does your carrier allow that?
  4. deepakpanwar_ Cupcake Dec 20, 2018
  5. Kytharsis Lollipop Dec 20, 2018
  6. deepakpanwar_ Cupcake Dec 21, 2018
    deepakpanwar_, Dec 21, 2018 :
    i downloaded CPU-Z but it was not opening so u downloaded another app .. see the thermals
  7. Alvie The Lab - OnePlus 5T Reviewer Dec 21, 2018
    Kytharsis likes this.
  8. prahwalp79 Cupcake Dec 24, 2018
  9. rahul2008d Cupcake Dec 24, 2018
    rahul2008d, Dec 24, 2018 :
    Please can anyone tell me how to make google camera work in OP 6. play store showing not supported. Is there any way?
    N.B. I tried searching for similar posts but unable to find any.
  10. R1529929162935 Cupcake Dec 25, 2018
    R1529929162935, Dec 25, 2018 :
    my one plus 6 front and back fully cracked. display is not working and phone slightly bend. Is it possible to repair my phone.? approximately how much cost to repair my phone.?
  11. G1545817889037 Cupcake Dec 26, 2018
    G1545817889037, Dec 26, 2018 :
    incoming calls are not showing on locked screen as well as pop is not working on unlocked screen also .. but the phone always ring while a call
  12. KrIstIaN430 Froyo Dec 29, 2018
  13. Y1544190850768 Cupcake Dec 29, 2018
    Y1544190850768, Dec 29, 2018 :
    Ужасное меню запущенных приложений, одна вкладка на весь большущий экран. Посмотрите у MIUI.
  14. chazey2 Ice Cream Sandwich Jan 1, 2019
    chazey2, Jan 1, 2019 :
    Download and install top one (30/12/18)
    https://www.celsoazevedo.com/files/android/google-camera/dev-arnova8G2/
    Will add another camera (Google) you can use either stock or gcam as you wish.
    Guide for good settings
    https://forum.xda-developers.com/showpost.php?p=78547556&postcount=5742
  15. niaz.ahmd Cupcake Jan 12, 2019
  16. Gugaraj Eclair Jan 18, 2019
  17. KingBizzleLord Froyo Jan 25, 2019
    KingBizzleLord, Jan 25, 2019 :
    When connected to earphones and listening to music at high volume, Call Volume through earphones is very high and is very painful to ears. any solution? checked the earphone mode and changed the notification sound through earphones to never. even though the problem exists - Oneplus 6 (9.0.3 OTA)
  18. W1548441097529 Cupcake Jan 25, 2019
    W1548441097529, Jan 25, 2019 :
    The face unlock system is slow and sometimes useless in low light. Any thing that I can do to eradicate this problem?
  19. Kytharsis Lollipop Jan 25, 2019
    Kytharsis, Jan 25, 2019 :
    Ditch face unlock. ;)
    drl431 likes this.
  20. avinash.gandhavi Cupcake Feb 6, 2019
