69
OP6T [Q&A] The Ultimate OnePlus 6T Guide
  1. Sancheet Maheshwari
    Cupcake Dec 5, 2018
    Sancheet Maheshwari , Dec 5, 2018 :
    hello form last 2 days I am facing heating issues in my phone . and battery is draining very fast. it is showing goolgel play services is draining maximum battery.what should I do.
  2. johneebee
    The Lab - OnePlus 7 Pro Reviewer Dec 6, 2018
    johneebee , Dec 6, 2018 :
    Hey thanks for all the help!! I think I found the issue but I don't know how to completely resolve it..
    So I found out that when I try and download something (like a file from facebook or an image from chrome), that my phone vibrates but doesn't actually let me tap a notification to open the downloaded file.. When browsing the download folder using a filemanager app/ connected with my laptop I can't seem to find new downloaded content in the downloads folder, but I can see the files in that folder when I use the standard "downloads" app and delete the files from there that were giving me a notification/vibration every 12 hours. Sorry to ask you again, but any idea how to fix it so that files can get downloaded normally again with normal notifications?
    already cleared cache, restarted and cleared everything from the download manager + checked that notifications were on for it, deleted and reinstalled facebook and chrome.. and restated the phone multiple times
    Alvie likes this.
  3. S1541657566149
    Donut Dec 7, 2018
  4. F_Rohini_Neelkantha_Kala
    Cupcake Dec 7, 2018
  5. S1541657566149
    Donut Dec 7, 2018
    S1541657566149 , Dec 7, 2018 :
    Facing the same issue
  6. Alvie
    The Lab - OnePlus 5T Reviewer Dec 7, 2018
    Alvie , Dec 7, 2018 :
    Clear cache of the camera app
  7. Alvie
    I'm not sure what could be causing it, but maybe try to go to settings > apps > show system (three dots) and for each of the following apps, click on them, then click storage and Clear storage (or clear cache if clear storage is not available):
    Android System
    BugReportLite (force stop this also)
    OnePlus System
    OnePlus System Service
    OnePlus LogKit
    Push
    Storage Manager
    System Framework
    System UI
    Settings Storage
    Settings
    If you had changed any settings, then you might need to change them again after doing this.
    johneebee likes this.
  8. F_Rohini_Neelkantha_Kala
    Cupcake Dec 7, 2018
  9. decorres
    Cupcake Dec 9, 2018
    decorres , Dec 9, 2018 :
    is there a possibility to remove YouTube from the battery optimation? I do often stream YouTube to my Chromecast and if the YouTube app being closed by the ram management I can't control YouTube from the status bar/Lockscreen, Till I open and reconnect YouTube again with the Chromecast. really annoying and because it's a system app I can't remove the optimation like in normal apps..
  10. Zeusc4
    Eclair Dec 10, 2018
    Zeusc4 , Dec 10, 2018 :
    ROOTED PHONE - Simple issue
    When my phone is Off
    I connect it via USB cable
    I get stuck at Warning message saying your bootloader is unlocked etc
    Of course Volume Up + Power Button solved it
    But its really annoying. What can I do?
  11. TheAyushJain
    Honeycomb Dec 10, 2018
  12. Daves89
    Donut Dec 11, 2018
  13. Pujain909
    Donut Dec 11, 2018
  14. L1544561255092
    Cupcake Dec 11, 2018
  15. RijulaMBanerjee
    Donut Dec 11, 2018
    RijulaMBanerjee , Dec 11, 2018 :
    Any idea what switching on 'storage manager' option in storage will do? What is it for anyways? Anyone?
  16. Ares1000101
    Cupcake Dec 12, 2018
    Ares1000101 , Dec 12, 2018 :
    If you click on the word storage manager it opens up and you will see a description, it auto deletes pictures from your phone after a set number of days.
  17. C1545185590111
    Cupcake Dec 19, 2018
  18. A1545213389347
    A1545213389347 , Dec 19, 2018 :
    Does anyone know if it's possible to add more home screens as mine only has 3 and I need more. Thanks.
  19. Steve Dan
    Cupcake Dec 22, 2018
    Steve Dan , Dec 22, 2018 :
    I've tried 3 separate times to use Wal-Mart pay within the Wal-Mart app. it seems the phone won't scan the QR code to pay.I checked the app settings and allowed all permissions. Cards are in app with security codes. I have used this on my LG G6 without a problem but, I don't have that phone any longer because I traded it in for this one. .
  20. Steve Dan
    I'd say, call your local T-Mobile and ask.
    C1545185590111 likes this.
