69
OP6T [Q&A] The Ultimate OnePlus 6T Guide
  1. A1545213389347
    Cupcake Dec 22, 2018
    A1545213389347 , Dec 22, 2018 :
    It's ok, I've worked it out myself thanks after 3 days with no reply [e]1f602[/e][e]1f602[/e] Some community this is !! If anyone else wants to know if you just drag something off to the left of your last home screen, it makes another one [e]1f44d[/e][e]1f44d[/e]
    O1545713351217 likes this.
  2. C1545185590111
    Cupcake Dec 23, 2018
    C1545185590111 , Dec 23, 2018 :
    Thanks, I poked around the original T Mobile advertisement and it looks like you can still. Same deal plus you have to add another new line.
  3. SapSet
    Froyo Dec 23, 2018
    SapSet , Dec 23, 2018 :
    This is how the OnePlus 6T is photographed. Night mode. What is this terrible noise in the photo ??? I think this is a mockery. Employees of OnePlus do you think this is a decent quality of shooting your flagship at night?
  4. JonasBarram
    Cupcake Dec 25, 2018
    JonasBarram , Dec 25, 2018 :
    Hello, coming from a Motorola with dual SIM experience, is it possible to have a different colour for each SIM when receiving a call? Thanks
  5. L1545850402960
    Cupcake Dec 26, 2018
    L1545850402960 , Dec 26, 2018 :
    Do We Have To Turn On/Wake Screen Before We Use The In Screen Fingerprint Scanner
  6. jlalcalar
    Donut Dec 29, 2018
    jlalcalar , Dec 29, 2018 :
    has a solution for using the band 3 (1800 MHz) at 4G LTE? It is used common in Spain and Venezuela. My OnePlus 6T is having trouble using this band.
  7. Alvie
    The Lab - OnePlus 5T Reviewer Dec 29, 2018
    Alvie , Dec 29, 2018 :
    Band 3 should work out of the box, contact your network provider if you have any issues.
  8. jlalcalar
    Donut Dec 29, 2018
    I have contacted the provider. When they use my simcard in another phone works perfect. They told me the problem is the compatibility of OnePlus 6t . I have bought the international version, but the sent me a T-Mobile version
  9. Alvie
    Oh, okay I understand. Where did you buy the phone from?
  10. jlalcalar
    Donut Dec 29, 2018
    i bought it at the oneplus.net the official website. My provider thinks they made a mistakes because I bought an internaltional version and they sent a T-Mobile version.
  11. Alvie
    There's nothing to indicate you are on the T-Mobile version though. The A6013 number is across the international and T-Mobile versions. Your build number also corresponds to OxygenOS 9.0.7 which I do not believe has been rolled out to T-Mobile yet.
    Try updating to 9.0.10 first (perhaps use a VPN and set it to Canada and check for updates) and check if the problem reoccurs.
    Also, what makes you think you received the T-Mobile version?
  12. jlalcalar
    Donut Dec 29, 2018
    at forum and internet says that
    Alvie likes this.
  13. cbj4074
    Eclair Dec 29, 2018
    cbj4074 , Dec 29, 2018 :
    That information is not accurate. I have the international variant and my model number is the same as yours, @jlalcalar : A6013.
    Alvie likes this.
  14. jlalcalar
    Donut Dec 29, 2018
    ah ok.I will try to get the update software to check the problem be fixed. Thanks You
  15. jlalcalar
    Donut Dec 29, 2018
    I will try to get the update..thanks you
    Alvie likes this.
  16. Mir.Iam
    Cupcake Dec 29, 2018
  17. ZoCoRi
    Donut Dec 31, 2018
    ZoCoRi , Dec 31, 2018 :
    i have a problem with my notifications in the from that i can't further open the notification to press the reply on whatssapp(example) it won't work and don't know a way to fix it, is it a bug or something just with the phone?
    i am on the 9.0.11 OS
  18. cbj4074
    Eclair Dec 31, 2018
    cbj4074 , Dec 31, 2018 :
    Are you sliding down on the individual notification? That's how they are expanded in OxygenOS. It takes some finger dexterity but works well.
    Alvie likes this.
  19. ZoCoRi
    Donut Jan 1, 2019
    ZoCoRi , Jan 1, 2019 :
    yeah i am but then my options on top just slide down andbit fully ignores the notification
  20. Alvie
    The Lab - OnePlus 5T Reviewer Jan 1, 2019
    Alvie , Jan 1, 2019 :
    Is that in portrait or landscape or both?
