66
OP6T [Q&A] The Ultimate OnePlus 6T Guide
  1. Sammy Sam
    Froyo Nov 7, 2018
    Sammy Sam , Nov 7, 2018 :
    How come the "quick launch" setting is not on the T-Mobile version? ..just watched a video of the setting on YouTube & my T-Mobile version doesn't have it. what else separate this version from the unlock version i guess?
    #81
  2. Infectafibian
    Cupcake Nov 8, 2018
    Infectafibian , Nov 8, 2018 :
    loving this phone... however I haven't been able to figure out how to use "split screen" on my 6t... honestly, am I missing something?....
    #82
  3. Sammy Sam
    Froyo Nov 8, 2018
    Sammy Sam , Nov 8, 2018 :
    Go to recent app mode & tap on the 3 dots on top right corner
    #83
    Infectafibian likes this.
  4. Alvie
    The Lab - OnePlus 5T Reviewer Nov 8, 2018
    Alvie , Nov 8, 2018 :
    Get to apps window by sliding up from bottom of phone and holding in the middle, above the app window there are three dots where when you click it will give you the option to split screen
    #84
  5. Infectafibian
    Cupcake Nov 8, 2018
    mine only shows unlock, full screen, and app info.... nothing that says split screen
    #85
  6. Sammy Sam
    Froyo Nov 8, 2018
    #86
  7. Infectafibian
    Cupcake Nov 8, 2018
    #87
  8. Sammy Sam
    Froyo Nov 8, 2018
    No problem bro
    #88
  9. Infectafibian
    Cupcake Nov 8, 2018
    I'm having trouble accessing Google assistant or "ok Google on my 6t anyone else having this issue? I have the T-Mobile version
    #89
  10. G1541645192573
    Cupcake Nov 8, 2018
    G1541645192573 , Nov 8, 2018 :
    hello guys...good morning. I have purchased the one plus 6T yesterday. but my device is always at vibration mode. Can't set the call volume or ringtone. even after upgrading the software, the problem exists. kindly help
    #90
  11. Pearlmikejam
    Eclair Nov 8, 2018
    Pearlmikejam , Nov 8, 2018 :
    Make sure the switch on the top right, above the power button, is in the lowest position. Mine was in vibrate out if the box too and I had to slide it down 1 click for sound.
    The lowest position is ring, middle is vibrate and top is silent. I didn't realize it was a slider switch. I thought it was a button.
    I hope this helps.
    #91
  12. G1541645192573
    Cupcake Nov 8, 2018
    thanks. I did the same and now it's ringing.
    #92
  13. paul.stohr
    Cupcake Nov 8, 2018
    paul.stohr , Nov 8, 2018 :
    Sorry, off topic, need to get a hold of support, as the system won't allow me to create a new thread, get the following message
    OnePlus Community - Error
    You do not have permission to view this page or perform this action.
    I can only comment on other threads, really annoying, need to find resolution for DND not working (always vibrates).
    #93
  14. Pearlmikejam
    Eclair Nov 8, 2018
    You can only create a topic in one forum your first 15 days after registering. I don't recall the forum but it should be in one of the messages you received.
    Your best bet is to post here to see if anyone can help.
    #94
  15. Jhester1967
    Donut Nov 8, 2018
    Jhester1967 , Nov 8, 2018 :
    My screen has a rainbow looking effect when screen is off and I'm not sure if it's the screen or screen protector. I put this 6t side by side with my 6 and its only on the 6t. anyone else have this issue?
    #95
  16. Shashank_Dave_
    Cupcake Nov 8, 2018
    #96
  17. Alintya
    Cupcake Nov 9, 2018
    Alintya , Nov 9, 2018 :
    Am I the only one not being able to flash magisk due to /sdcard being encrypted?
    #97
  18. Alvie
    The Lab - OnePlus 5T Reviewer Nov 9, 2018
    Alvie , Nov 9, 2018 :
    It's not the screen protector. Don't worry about it, it's just the way the device/screen looks
    #98
  19. Alvie
    #99
  20. Alvie
    Did you flash TWRP and follow all of the instructions correctly?
