69
OP6T [Q&A] The Ultimate OnePlus 6T Guide
  1. HansAnonymous
    Cupcake Nov 28, 2018
    HansAnonymous , Nov 28, 2018 :
    Picture-in-Picture mode will only work in certain scenarios. For example: YouTube will only allow a majority of non-music videos to be played in PIP. Some other videos are also prohibited from playing in PIP. You should also get into PIP from vertical orientation on the phone, either going to the recents menu or the home screen. Google Maps works just fine for PIP as well for me!
  2. HansAnonymous
    Restart your phone! (Holding power button, then tapping restart). If not, try using cellular data instead of of wifi, or vice versa. Try switching wifi networks as well. It is a little finicky, as was with mine. Try stopping and restarting the downloads/updates. I let it run overnight though it didn't seem like it was downloading and all my apps were recovered!
    Alvie likes this.
  3. Steve Dan
    Cupcake Nov 29, 2018
    Steve Dan , Nov 29, 2018 :
    my OP 6T shuts itself off at night. when I wake in the morning I have to hold the power button to turn it on. This happens if it is connected to the charger and not connected to the charger. is this normal??
  4. Alvie
    The Lab - OnePlus 5T Reviewer Nov 30, 2018
    Alvie , Nov 30, 2018 :
    Doesn't seem normal to me, check these settings:
    Settings > Utilities > Scheduled Power Off/On and set something there and then remove it
    Steve Dan likes this.
  5. Steve Dan
    Cupcake Nov 30, 2018
    Alvie likes this.
  6. J1541502024229
    J1541502024229 , Nov 30, 2018 :
    OnePlus 6t has large display due to this it's so difficult to pickup calls while driving OnePlus should give one-handed mode in it's next software update
  7. Caribeno
  8. Alvie
    It's possible in Nova Launcher, not sure about OnePlus one
  9. devangmehta07
    Cupcake Dec 1, 2018
    devangmehta07 , Dec 1, 2018 :
    use Bluetooth
  10. Infectafibian
    Cupcake Dec 2, 2018
    Infectafibian , Dec 2, 2018 :
    Alvie, I have a question... I've tried to hook up my 6t USBC to USB to watch movies on my TV that I have on my phone... this used to work in my s8+...I don't understand why I can't do it with my 6t.... can you please help or give me an answer as to why?
  11. HenrikOnePlus
    Eclair Dec 2, 2018
    HenrikOnePlus , Dec 2, 2018 :
    That must be the T-Mobile version then. My handset (Europe) came with a tray to hold 2 SIMs, and I'm using both.
  12. HenrikOnePlus
    Eclair Dec 2, 2018
    Settings - Quick gestures, first option on mine is "Flip to turn off sound" - well maybe not those exact words as my handset is set to Danish. :)
    Alvie likes this.
  13. johneebee
    The Lab - OnePlus 7 Pro Reviewer Dec 3, 2018
    johneebee , Dec 3, 2018 :
    Anyone having random vibrations (like 2-3 times a day) without seeing any notifications? Been having them for the last 3 days.
    Any idea how to see what is causing them/ how to stop them?
  14. Alvie
    The Lab - OnePlus 5T Reviewer Dec 3, 2018
    Alvie , Dec 3, 2018 :
    Sorry, I can't think of why that would be happening - is there anything in Settings > Battery > Usage Totals that's out of the ordinary?
  15. johneebee
    The Lab - OnePlus 7 Pro Reviewer Dec 4, 2018
    johneebee , Dec 4, 2018 :
    This time I saw the notification for like half a seconde before it disappeared, "download complete" and than the name of an image file. When I looked for it, it was a file in the folder "...->instabug->usersteps". I'm guessing this is some kind of bug report map? Is there any way to disable this automatic saving of images in that file (mainly, a way to not have random vibrations in the middle of the night?)
    Thank you in advance!
  16. Alvie
    The Lab - OnePlus 5T Reviewer Dec 4, 2018
    Alvie , Dec 4, 2018 :
    Try going to Developer's Options, then towards the top it says "Get Logs", click that and choose "Delete History Log" and on the same page scroll down to the bottom and choose "advanced" and then "Clear cache"
    johneebee likes this.
  17. johneebee
    Alvie
    Try going to Developer's Options, then towards the top it says "Get Logs", click that and choose "Delete History Log" and on the same page scroll down to the bottom and choose "advanced" and then "Clear cache"​
    thank you for the help, sadly still getting the vibrations with "download completed step3-1.png" for half a second and then disappearing
  18. Alvie
    The Lab - OnePlus 5T Reviewer Dec 5, 2018
    Alvie , Dec 5, 2018 :
    Is USB debugging enabled on your phone? If so, try disabling it and see if it still occurs
  19. johneebee
    The Lab - OnePlus 7 Pro Reviewer Dec 5, 2018
    johneebee , Dec 5, 2018 :
    no, it sadly isn't on, hope I won't have to factory reset my phone
  20. Alvie
    I'm struggling to find any decent results on Google matching with what you're experiencing.
    Before you factory reset or anything of that sort, try to clear cache in recovery
