100
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. J1558480361064
    Cupcake Jan 12, 2020
  2. cadeepakbansal
    Gingerbread Jan 12, 2020
    cadeepakbansal , via OnePlus 7T , Jan 12, 2020 :
    I accidentally clicked on the Agreed button in the survey wizard to use personal data from my device, but now I am worried about any leakage or misuse of any personal information. I also thought whether the survey form that I had received was a Phishing or from a unknown source.
    Please advise me, so that no misuse will be there.
  3. Vikasnarula17
    Vikasnarula17 , Jan 12, 2020 :
    Hello Geeks...Need one suggestion
    Suppose I have a contact no. And the same is saved as some name... Now when I call or receive call from that contact... Name reflects along with number.. I want only the name should reflect... Not the no.
  4. Vikasnarula17
  5. Alvie
    The Lab - OnePlus 5T Reviewer Jan 14, 2020
    Alvie , Jan 14, 2020 :
    I don't think that's an option to set with the default dialer app, but perhaps there is a third party app that you can achieve this with.
    What is the reasoning behind not seeing the number? It's not standard for any phone to hide this.
  6. Alvie
    File a bug report as well as try to alert DirecTV to see if it's something on their end
  7. Alvie
    You will have to contact support regarding this: https://oneplus.com/support
  8. I1578980007007
    Cupcake Jan 14, 2020
    I1578980007007 , Jan 14, 2020 :
    plz improve the quality and smoothness in slow motion its disgusting very bad.. even normal phones have better slow motion from one plus 7t
  9. Vikasnarula17
    Vikasnarula17 , Jan 14, 2020 :
    dear... the very important reason for hiding the number of contact saved is when you are in public place..if any contact called you and someone is looking at your phone... that person can note down the number and name... you know...in iPhone this is the default feature... I am not comparing... just giving the suggestion..it must be included in android also..
  10. J1558480361064
    Cupcake Jan 15, 2020
  11. Alvie
    The Lab - OnePlus 5T Reviewer Jan 16, 2020
    Alvie , Jan 16, 2020 :
    I don't work for OnePlus and don't owe it to anyone to actually do anything. If you have filed a bug report, someone from the OnePlus software team will look into it.
    scp41 likes this.
  12. J1558480361064
    Cupcake Jan 16, 2020
  13. Alvie
    The Lab - OnePlus 5T Reviewer Jan 17, 2020
  14. Xetmes
    Gingerbread Jan 19, 2020
  15. Alvie
    The Lab - OnePlus 5T Reviewer Jan 20, 2020
    Alvie , Jan 20, 2020 :
    I think it will be a shortly after the OnePlus 8 series are launched but this is just a guess
  16. W1578478310042
    Cupcake Jan 23, 2020
    W1578478310042 , Jan 23, 2020 :
    My one plus 7T have hanging issue daily, shoot video for 10 minutes at night with flash after that unable to turn off flash light and started hanging after restart working fine, daily while using Whatsapp i am facing the hanging issue, after restart working fine, any solution? or everyone facing the same issue?
  17. Renffah
    Eclair Jan 23, 2020
    Renffah , Jan 23, 2020 :
    Last week I forgot my 7T at home. When I came back, 3–4 hours later, it was powered off, even though it had around 60–70 % of battery.
    Neither I could power it on, nor it showed any reaction when I attached the charger. Tried other chargers, power bank, my Notebook, and different cable combinations, nothing.
    I had to hold the Vol up+down and Power Buttons and boot recovery to wipe the cache.
    After it successfully booted, the battery was around the same amount it was charged, when I left home.
    Had the feeling, the touchscreen was a bit to sensitive (glide typing), but next day, it was okay as before.
  18. Alvie
    The Lab - OnePlus 5T Reviewer Jan 23, 2020
    Alvie , Jan 23, 2020 :
    What version of OxygenOS are you using and are all of your apps updated?
  19. Renffah
    Eclair Jan 24, 2020
    Renffah , Jan 24, 2020 :
    Oxygen OS 10.0.7.HD65BA, all Apps are up-to-date. Hadn't this neither befofre nor after that, the 7T is running fine.
    I'm just curious, if somebody else had experienced this problem — and started to panic. If it happens again, I will let you know.
  20. W1578478310042
    Cupcake Jan 24, 2020
    W1578478310042 , Jan 24, 2020 :
    Oxygen OS 10.3.0.HD65AA, All apps are upto date
    Riekje likes this.
