75
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. gagan.g12
    Cupcake Feb 21, 2020
    gagan.g12 , via OnePlus 7T , Feb 21, 2020 :
    all settings are ok...and got the solution from one plus team
    Alvie likes this.
  2. cadeepakbansal
    Froyo Feb 23, 2020
    cadeepakbansal , via OnePlus 7T , Feb 23, 2020 :
    In Smart Tv - Switch on the Screen mirroring / Listen mode
    In 7T - First Switch on Wifi toggle, then go to Screen Cast then search your Tv & connect.
    I have 7T & I always successfully connect like this.
    K1581257590155 likes this.
  3. G_its_me_rFpq
    Cupcake Feb 25, 2020
    H1521269864833 likes this.
  4. Judah000
    Judah000 , Feb 25, 2020 :
    Hello I have a request to add the following features to help our experience better as we use our phones on a day to day basis.
    Please add a picture in picture overlay for when a notification is received. A small bubble will pop up and the user can press it, which will open a small window of the app the notification came from.
    My phones microphone is having some kind of problem or it could be something related to it. When I'm talking to someone on a call, there telling me they cannot hear me well enough. The same thing goes for when I use my jaybird tarrah pro Bluetooths. Is the support team working on a fix, also I just purchased this phone this past November and haven't dropped or damaged it?
    Please add schedule texting so we would be able to set a date and time for a text message to be sent to a recipient. Very useful
    If anyone else has something to add please do share.
    Thank you One Plus team
    Alvie likes this.
  5. G1572469583021
    Gingerbread Feb 25, 2020
    G1572469583021 , Feb 25, 2020 :
    this is just a community forum, you need to submit a bug report or a feedback report what you can do through the app as well. by pressing the plus icon in the bottom right corner and submit feedback and or bug report.
    Alvie likes this.
  6. Alvie
    The Lab - OnePlus 5T Reviewer Feb 27, 2020
    Alvie , Feb 27, 2020 :
    Yes it will, you may still get the notifications but they usually won't work. Sometimes the full files come through and may work but you may lose root and have to reflash
    G_its_me_rFpq likes this.
  7. Alvie
    Unfortunately this is beyond my scope, while I'd love to be able to help, it's sounds like it's a better job for the OnePlus support team. You can file a bug report here: https://forums.oneplus.com/forums/oneplus-7t-support/
    Have you tried using a voice recorder app and seeing if the microphone has poor quality there?
  8. Alvie
    Likely shortly after 8 (Series) is launched but I could be wrong
  9. E1582767875102
    Cupcake Feb 27, 2020
  10. G1572469583021
    Gingerbread Feb 27, 2020
    G1572469583021 , Feb 27, 2020 :
    I have not had this issue mine is not blurry.
  11. Judah000
    Judah000 , Feb 27, 2020 :
    I have not, I will try ur idea to see if there's something wrong with my microphone
    Alvie likes this.
  12. dkhajavi
    Cupcake Feb 29, 2020
    dkhajavi , Feb 29, 2020 :
    Beware USA buyers of the 7TPRO MC! OnePlus will not support this phone like you may have been supported in the past. After software issues I waited over a month to only be told that OP did not have software available for the T-Mobile phone. I had to return the phone to TMo for a simple software issue that should have taken a few mins to fix but instead was without my device for over a month because OP does not want to support this device on TMo. Also beware this is a single sim phone that currently, and likely for a long time , if ever will NOT be able to be switched over. Having had several OP phones in the past I fear this is my last. It is just not the company it used to be.
  13. G1572469583021
    Gingerbread Feb 29, 2020
    G1572469583021 , Feb 29, 2020 :
    I have also talked to one plus anyone get a different story from them they are supporting the phone T-Mobile has got another software update with February security patch I have the OnePlus McLaren on T-Mobile have no issues with it I'm not sure what it is you had. since you do not State them. but I have talked to one plus they are the ones doing the updates for T-Mobile for the OnePlus 7t pro 5G McLaren. I mean we got to updates in February want to fix some 5G issues and speeds another one that gave us some improvements and February security update. I have not taken this update just yet I will later this afternoon. but as I have stated I have talked to both T-Mobile and OnePlus both have stated that one plus is the one doing the updates for T-Mobile's OnePlus variance they do the updates for both the 7t and the 7t pro. if you have issues with it and have bug reports you submit them to the community app or call one plus or even talk to T-Mobile and T-Mobile Will submit them for you.
  14. Zatchu2
    Zatchu2 , Feb 29, 2020 :
    I'm glad you posted this. I was thinking about getting one for the Visible service but now thanks to you I know that I shouldn't. I have the Oneplus 6t and I tried it on it but nada I could make phone calls but off and on with internet 😁 Thank You
    zerobeatpro1 likes this.
  15. zerobeatpro1
    Eclair Feb 29, 2020
    zerobeatpro1 , Feb 29, 2020 :
    Zatchu2
    I'm glad you posted this. I was thinking about getting one for the Visible service but now thanks to you I know that I shouldn't. I have the Oneplus 6t and I tried it on it but nada I could make phone calls but off and on with internet [e]1f601[/e] Thank You​
    The 7T works with visible in NYC. I get around 100mbs download speed. submit a ticket to the OnePlus devs, it usually takes about a month or less for a update fix.
    Alvie and Zatchu2 like this.
  16. K1583943108689
    Cupcake Mar 11, 2020
    K1583943108689 , Mar 11, 2020 :
    Is the included charging brick a USB 2.0 or 3.0? I'm considering purchasing a different cable but I love the speed the brick offers, I just want to be sure I purchase the correct cable.
    Alvie likes this.
  17. Alvie
    The Lab - OnePlus 5T Reviewer Mar 11, 2020
    Alvie , Mar 11, 2020 :
    USB 2.0 is included. For warp charging, you'll need to use the included USB 2.0 cable. For data transfer/normal charging you can use any cable
  18. K1583943108689
    Ok thank you very much.
    Alvie likes this.
  19. Q1584289139143
    Cupcake Mar 23, 2020
    Q1584289139143 , Mar 23, 2020 :
    I use a 7T pro 5G and I can't figure out how to go back to a previous screen. I always had a Samsung phones previously and it is very easy to use a triangle sign to go back.
    any help is appreciated
    Alvie likes this.
