75
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. Alvie
    The Lab - OnePlus 5T Reviewer Mar 23, 2020
    Alvie , Mar 23, 2020 :
    You can swipe up from the bottom left or bottom right and it will work as the back button.
    You can change it to the traditional method like so by going to Settings > Buttons & gestures > Navigation bar & Gestures and set it to Back, Home and Recents.
    Personally I use the gesture based method, it did take a little while to get used to though. I'm uploading a gif to explain it:
    (I show how the swipe up works but you have to do it from all the way of the bottom of the screen)
  2. E1577249961510
    Cupcake Mar 24, 2020
    E1577249961510 , Mar 24, 2020 :
    Why can't I take panorama holding the phone horizontally?? shooting panoramas in vertically is not letting me get desired effect and captures....
  3. Alvie
    The Lab - OnePlus 5T Reviewer Mar 24, 2020
    Alvie , Mar 24, 2020 :
    I think it's because doing it vertically because it can capture a lot more information so it can help it stitch the photo together more easily and also end up with higher quality images and include more at the top and bottom. (You can always crop later I'd assume). You can always use a third party app if you'd like
  4. E1577249961510
    Yes, but when anyone who wants to capture a landscape would prefer holding phone horizontally.
  5. Alvie
    Either way it's 360° so you achieve the same result, you get a much more detailed landscape
  6. S1581587274954
    Cupcake Mar 27, 2020
    S1581587274954 , Mar 27, 2020 :
    battery backup is worst I want to charge the phone 3times a day please help me
    if I play plubg battery drains fastely [e]1f62d[/e][e]1f62d[/e]
  7. kamalkumar7852
    kamalkumar7852 , Mar 27, 2020 :
    i have a worse case...
    i have 2 sim jio and bsnl.
    some times the bsnl signal shows good but some times it shows "emergency call only" while other phones are getting signal.
    and my voice breaks when i use phone in speaker mode.
  8. Q1584289139143
    Cupcake Mar 29, 2020 at 3:56 PM
    Q1584289139143 , Mar 29, 2020 at 3:56 PM :
    I'm using 7T Pro 5G McLaren edition when connected to a Wi-Fi the sound quality is very bad I cannot hear the other person I have tried to remove the Wi-Fi connection by using the forget option and reconnect again I have also use the Wi-Fi connection in different places like my office my friends office and my brother's house problem still exists. I was able to talk to OnePlus tech support and they're recommending for me to replace the phone which I don't want to do because it takes a very long time to setup all apps. any recommendations?
  9. Alvie
    The Lab - OnePlus 5T Reviewer Mar 29, 2020 at 11:09 PM
    Alvie , Mar 29, 2020 at 11:09 PM :
    Is that with normal calls or with calls from apps like WhatsApp/messenger etc?
  10. Q1584289139143
    Cupcake Mar 29, 2020 at 11:11 PM
    Alvie likes this.
  11. Alvie
    The Lab - OnePlus 5T Reviewer Mar 29, 2020 at 11:24 PM
    Alvie , Mar 29, 2020 at 11:24 PM :
    When you're on these calls, does it so VoWiFi on the top (in the navigation bar)?
    If so, you can turn off VoWiFi in your settings, and it should use your normal network instead, like this:
    (Settings > Wi-Fi & Internet > SIM & Network Settings > SIM1/2 > toggle WiFi calling off)
  12. Q1584289139143
    Cupcake Mar 29, 2020 at 11:34 PM
  13. O1512042007238
    Cupcake Mar 30, 2020 at 3:52 AM
    O1512042007238 , Mar 30, 2020 at 3:52 AM :
    I'm not able to use resolution more than 480p in youtube streaming and I've tried deleting the app and again updating it, restricted data usage and then enabled it again, tried aeroplane mode on and off method. But still I'm facing the same problem. I hope you can give me any solution to resolve it
  14. O1512042007238
    Cupcake Mar 30, 2020 at 3:55 AM
    O1512042007238 , Mar 30, 2020 at 3:55 AM :
    I would suggest you to do a replacement since it is not worth it to use a mobile that expensive with those kind of complications . I'm using one plus 7T and it is randomly behaving weird sometimes like there are some minor bugs, even I have to contact the customer support.
    Alvie likes this.
  15. Aki1596
    Gingerbread Mar 30, 2020 at 4:37 AM
    Aki1596 , via OnePlus 7T , Mar 30, 2020 at 4:37 AM :
    YouTube restricted streaming quality to 480p on android devices in india
    https://www.xda-developers.com/yout...ality-480p-standard-definition-india-covid19/
    O1512042007238 and Alvie like this.
  16. Alvie
    The Lab - OnePlus 5T Reviewer Mar 30, 2020 at 5:38 PM
    Alvie , Mar 30, 2020 at 5:38 PM :
    YouTube have limited it to 480p in some regions, are you perhaps in India?
    https://9to5google.com/2020/03/30/youtube-india-480p-restriction/
    It's because of the extra traffic they're getting on the website due to the quarantine, they have to limit it
    O1512042007238 likes this.
  17. Alvie
    The Lab - OnePlus 5T Reviewer Mar 30, 2020 at 5:44 PM
    Alvie , Mar 30, 2020 at 5:44 PM :
    If VoWiFi isn't available for your device, it seems like your network doesn't support WiFi calls which to me would suggest that your WiFi should not be affecting your phone. Perhaps try another network or in the unfortunate scenario that nothing helps, then a factory reset and then return for repairs/replacement. There are some ways you can make a reset easier. Make sure to back up everything. Photos can be done with Google Photos, some app data like WhatsApp and games can be backed up to your Google or Facebook account for example.
  18. O1512042007238
    Cupcake Mar 30, 2020 at 5:51 PM
    Alvie likes this.
  19. Assassin786
    Cupcake Mar 30, 2020 at 6:46 PM
  20. G1572469583021
    Gingerbread Mar 30, 2020 at 7:32 PM
    G1572469583021 , Mar 30, 2020 at 7:32 PM :
    you're going to have to manually switch the resolution on YouTube Auto is always going to go to 480i
