85
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. AkshayHadapad
    Cupcake Mar 30, 2020
  2. Q1583313953648
    Cupcake Apr 3, 2020
    Q1583313953648 , Apr 3, 2020 :
    In normal mode my one plus 7t vibrates while receiving sms or a notification. if I keep the notifications off in normal mode then it notifications doesn't vibrate in vibration mode . can someone help ?
  3. MaremanndhaSR
    Cupcake Apr 6, 2020
    MaremanndhaSR , via OnePlus 7T , Apr 6, 2020 :
    Hi team,
    I am using few bluetooth devices like smart watch and head phones, but the devices are not auto connected.. each time I have to go to bluetooth setting and click on the device that I want to use.
    in one plus 6T I didn't find this issue.. whenever I switch on the devices they auto connect.. can you help me in how can I auto connect to my new one plus 7T.
  4. A1574941417327
    Cupcake Apr 11, 2020
    A1574941417327 , Apr 11, 2020 :
    Hi,
    i am using OnePlus 7t pro McLaren edition.. and since two or three months now i am facing a issue with whatsapp video recording like when I try to record video through whatsapp camera it doesn't records the voice at all.... and video it self is very flickery like it hangs or lacks frame rate.... but the main camera is fine it records the video with voice but even if i post a video from main camera over whatsapp, the frame rate lackss like a slow motion video.... can any one please guide me what's this issue could be, bcause i already un installed whatsapp and re installed it but the issue is still there........
    peace,,[e]270c[/e]️
  5. A1574941417327
    may be you are using power saving mode continuously because the phone doesn't vibrates over power saving mode
  6. Q1583313953648
  7. cadeepakbansal
    Gingerbread Apr 11, 2020
    cadeepakbansal , via OnePlus 7T , Apr 11, 2020 :
    Q1583313953648
    In normal mode my one plus 7t vibrates while receiving sms or a notification. if I keep the notifications off in normal mode then it notifications doesn't vibrate in vibration mode . can someone help ?​
    Okay, I am trying to help you.
    Some tweaks are required:
    Open Settings > In search bar type "Notification" > Enter Notification Vibration > 3 Settings are there, adjust as per your requirement.
    One more thing regarding Notification setting related to Alert Slider
    Open Settings > In search bar type "Slider" > Enter Alert Slder > Change Vibration setting in Ring mode.
    I hope this works.
    Alvie likes this.
  8. Q1583313953648
    Cupcake Apr 12, 2020
    Q1583313953648 , Apr 12, 2020 :
    thank u for the help. option 1 worked [e]1f44d[/e]
    Alvie likes this.
  9. cadeepakbansal
    Gingerbread Apr 12, 2020
    Alvie likes this.
  10. Alvie
    The Lab - OnePlus 5T Reviewer Apr 13, 2020
    Alvie , Apr 13, 2020 :
  11. targnik
    Eclair Apr 19, 2020
    targnik , Apr 19, 2020 :
    Oneplus home/launcher/app drawer - needs to be able to access installed icon packs (not just default), so we can further edit icons.
    Many apps people install will be unique to their region and being able to use other icons within custom icon packs will keep things looking trick.
    Thanks.
  12. O1512042007238
    Cupcake Apr 24, 2020
    O1512042007238 , Apr 24, 2020 :
    i did hard reset on my phone as i forgot my password and then i updated it to the latest software, but now I'm facing a problem. I'm not getting any notification for calls ! "To answer any call i need to unlock the phone from blank screen and then push down notification bar and answer the call" . the funniest part is i done even know who's calling without following all the steps above . if there is anyone had similar issues please help me out
  13. M1574449129525
    Cupcake Apr 25, 2020
    M1574449129525 , Apr 25, 2020 :
    My phone is OnePlus 7t
    model HD1901
    I HAVE A PROBLEM WITH PHONE SPEAKER
    I CANT GET A VOICE DURRING TO MAKE A CALL
    OR ALL INCOMING CALLS!
  14. O1512042007238
    O1512042007238 , Apr 25, 2020 :
    i thought the one plus OS is pretty good but dude this actually is not that good and nobody can react to any query spontaneously.
  15. M1570176202701
  16. DragonShaft
    Eclair Apr 28, 2020
    DragonShaft , via OnePlus 7T Pro , Apr 28, 2020 :
    Why is no one talking about Touch Lag on 7T Pro?
    I mean I bought this phone for gaming (big mistake I know, could have gone for ROG 2)
    But aiming on this phone while playing CODM is a nightmare.
    Turning left/right is floaty and sluggish especially when you have multiple fingers on the screen due to the Touch Lag.
    Fvcking pathetic waste of good snapdragon 855+ hardware if the touchscreen or touch integration with the software is BS.
    And people talk about how OxygenOS is the best really haven't used this phone for more than texting, I believe 🤦‍♂️
    kamalkumar7852 likes this.
  17. PieSwagoras
    Cupcake May 2, 2020
    PieSwagoras , via OnePlus 7T , May 2, 2020 :
    Navigation bar: just came from a 6T to a 7T and there is no option to hide the navigation bar temporarily? Only on or off-gestures instead?? I loved this feature on 6T and 7Pro phone has this feature. So confused why this has suddenly disappeared??
  18. G1572469583021
    Gingerbread May 2, 2020
    G1572469583021 , May 2, 2020 :
    what touch lag I've have no touch lock on my 7t pro McLaren. can you explain a little bit more. I play games and have had no issues
    SubhashNayak likes this.
  19. DragonShaft
    Eclair May 2, 2020
    DragonShaft , via OnePlus 7T Pro , May 2, 2020 :
    Yeah. I play CODM on this and having multiple fingers on the screen causes touch delay. The movements are floaty and a bit sluggish. Turning left/right seems like your player is moving through water lol.
    Only happens in the game tho
  20. DragonShaft
    Eclair May 2, 2020
    See above ^^
