113
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. Chris507
    Froyo May 24, 2020
    Chris507 , May 24, 2020 :
    I have one week using my New Oneplus 7T Hd1905 model. The only bug I've seen is that sometimes I am using social metworks or Google and suddenly the screen freezes so I have to go home and come back to the Page and can continue using.
    ironhorse99 and N1576935632292 like this.
  2. G1572469583021
    Gingerbread May 24, 2020
    G1572469583021 , May 24, 2020 :
    looks like your post this back in March after the March update I no longer had that issue and I have the same phone I have Crystal clear Wi-Fi calls
  3. kgatera
    Cupcake May 25, 2020
    kgatera , via OnePlus 7T , May 25, 2020 :
    Hello, I just bought the 1+7t and switched to dark mode in the app but this article seems to be hard-coded with black letters. So part of the article wasn't visible. So, I had to switch dark mode off.
  4. ngydat
    Lollipop May 25, 2020
  5. kgatera
  6. ngydat
  7. SubhashNayak
    Honeycomb May 25, 2020
    SubhashNayak , via OnePlus 7T Pro , May 25, 2020 :
    That's right. I was wondering why is it all blank. Black letters should actually appear white when dark mode is on!
    aravindca25 likes this.
  8. SubhashNayak
    Why are you on community then? Have you used any of the oneplus device? Which phone do you use now by the way? I'm curious
  9. SubhashNayak
    Al @Alvie said, it depends on your budget. There's about 7k price difference between the two. Both are good one's in that range. If you can afford the 8, then it's a good option.
  10. SubhashNayak
    Which model do you use? I used to have this issue with whatsapp. Like the messages used to appear on the lockscreen for a second when I unlock the phone. But after the update two months back, it was solved. Never had any problems with gallery opening up in lock screen! Hope you are on updated version
  11. cadeepakbansal
    Gingerbread May 25, 2020
    cadeepakbansal , via OnePlus 7T , May 25, 2020 :
    SubhashNayak
    Why are you on community then? Have you used any of the oneplus device? Which phone do you use now by the way? I'm curious​
    You mean to say, Only those users should be on Community who write positive comments about OnePlus.
    By the way, If you can't see the signature below my post, I would please to tell you I have OnePlus 7T & I am on Community because I own OnePlus device & reveals the Bugs & problems in OnePlus Devices.
    Any problem you have?
    Klose507 likes this.
  12. G1572469583021
    G1572469583021 , May 25, 2020 :
    I'm curious what problems do you have with your OnePlus 7t you report bugs and problems. I have the OnePlus 7t pro 5G McLaren. and have gone great updates every month. And don't have that many issues. I'm just curious what is your having
  13. cadeepakbansal
    G1572469583021
    I'm curious what problems do you have with your OnePlus 7t you report bugs and problems. I have the OnePlus 7t pro 5G McLaren. and have gone great updates every month. And don't have that many issues. I'm just curious what is your having​
    My device is having Hardware issue.
    Green tint on top & Bottom half Screen, while using Grey Theme with low backlight. You are so curious, will you be able to solve this issue. Many software issues are also there, should I tell you?
  14. G1572469583021
    tell me about the software issues. Your hardware issues will you have them within the first year. because that's a manufacturer defect which you should call 1 + and get a replacement. software issues can be solved over updates but if you may be the only one having those issues then a factory reset might help. who knows those green tint might be software-related as well.
    like I said I would probably call OnePlus tomorrow or Wednesday and see if you can get a replacement. those hardware defects are manufacturer defects that you should be able to get it replaced if you're within the one-year warranty.
  15. cadeepakbansal
    I had purchased 7T in Oct 2019. It's more than 6 months & I have noticed the Screen defect during the Lockdown period.
    I purchased this from Amazon, will my device be replaced after 6 months & from OnePlus Retail Store?
  16. G1572469583021
    well it would not be replaced through Amazon. not sure of your locale you may have to call one plus and see what they can do for you. as they are the manufacturer and they would have to deal with the defect.
  17. cadeepakbansal
    Ya it's ok. I am from Delhi, India, my only query is just about period of around 6 months. Will OnePlus store be agree to entertain replacement after 6 months?
  18. G1572469583021
    if you have one plus stores in India than they should help you with replacement manufacturer warranties are a year four defects. so you should be able to get it replaced. though you might have to send it actually into OnePlus though. in the US we do not have one plus stores
    Alvie likes this.
  19. Arif1618
    Cupcake May 31, 2020
  20. M1576053304507
    Cupcake Jun 3, 2020
    M1576053304507 , Jun 3, 2020 :
    Hi currently I'm having issue with the new 720P 960FPS slow motion resolution. I've gotten this resolution after updating my Oxygen OS to 10.0.9 HD01AA from Oxygen Update app (Downloaded from Google Playstore). It seems like I am not able to record for more than 1 second and right after I pressed the red recording button, it stopped immediately and saved the video. The other two resolutions are doing fine (1080P and 720P 480FPS) which could record up to 1 minute timer. Anyone facing the same issue after updating it?
