46
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. O1571470956938
    Cupcake Oct 19, 2019
    maheshkumar006 likes this.
  2. Y1570304296630
    Q1526976290155 likes this.
  3. Q1571236013965
  4. R1571051305906
    R1571051305906 , Oct 19, 2019 :
    I have problem in pubg game first it's gyroscope sensor not working properly sometime and second one is app not exit with back button I have to press home button for close please improve it fast .thank you.
  5. Buntf
    sskamesh likes this.
  6. Alvie
    The Lab - OnePlus 5T Reviewer Oct 20, 2019
    Alvie , Oct 20, 2019 :
    Your Moto M will charge at either between 5V1A (5W) or 5V2A (10W) speeds. Nothing dangerous will happen
    E1570008488656 likes this.
  7. Alvie
    If you NEEDED 5G right now, then yes buy the 7 Pro 5G - BUT make sure 5G is available in your area (or at least will be soon). Otherwise, I'd recommend waiting for 8 Pro unless you also needed to upgrade for other reasons.
    gkourogiorgas likes this.
  8. Alvie
    Trust me, even that is REALLY good even for minimal use
  9. Alvie
    Have you noticed in any other apps? It doesn't happen to me in other apps that I use so it may be an error on Hike's behalf.
  10. Alvie
    It seems like the ambient display is a common issue that has been reported to be solved.by enabling adaptive brightness
  11. Alvie
    Sorry I don't quite understand? Does it hang in all apps or just some specific ones? Can you describe it in more detail please
  12. kalpesh6295
    Cupcake Oct 20, 2019
    kalpesh6295 , Oct 20, 2019 :
    actually I have only one app in which I have to use fingerprint sensor for authentication. you can also try. install hike and then hide your chat. they will ask if you want to use fingerprint or pattern. and after that sometimes when you unlock your secure chat in hike. you will notice that fingerprint scanner remain on screen.
  13. Alvie
    Ah, I see what you mean now. It may be worth reporting the bug both to OnePlus and Hike if you can. As it is just on that app (as far as we know at the moment) it maybe something that Hike has to fix but a well explained bug report may get looked into by OnePlus
  14. Alvie
    That shouldn't be the case, but it seems like it does happen quite frequently. The main thing I'd suggest would be to remove the PIN before going into recovery and then adding it back once you're done. Sorry it isn't ideal but I couldn't find any other solutions
    ks_oneplus likes this.
  15. Alvie
    Settings > Sound & vibration > Turn off Touch Vibration
  16. kalpesh6295
    how can I report a bug?
  17. Alvie
    Can you provide usage stats/more details please?
  18. Alvie
  19. E1570008488656
    E1570008488656 , via OnePlus 7T , Oct 20, 2019 :
    in some apps , when i use app the screen is stuck . i can't do anything on that app so i have to restart the app again.
    kalpesh6295 likes this.
  20. E1570008488656
    So i can charge moto m with my oneplus 7t warp 30t w charger ?
