36
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. Y1570304296630
    Cupcake Oct 20, 2019
    Q1526976290155 likes this.
  2. Y1570304296630
  3. D1570344717096
    Froyo Oct 20, 2019
    D1570344717096 , Oct 20, 2019 :
    really?? My old Samsung 2000 mAh battery gives a similar performance bought 2 yrs ago...
    what I liked with OnePlus is the quick action on issues noticed. Many of us have reported the battery drain issue. we look forward for a fix for the same.
    maheshkumar006 likes this.
  4. arbaz1998
  5. Alvie
    The Lab - OnePlus 5T Reviewer Oct 20, 2019
    Alvie , Oct 20, 2019 :
    I'd say anything more than 6:00 is really good! Phones today are a lot more powerful and due to the higher refresh rate and resolution it may offer similar performance to older lower powered phones with lesser resolutions
    scp41 likes this.
  6. ks_oneplus
    Gingerbread Oct 21, 2019
    ks_oneplus , via OnePlus 7T , Oct 21, 2019 :
    Though this question is not 7T specific, but I wanted to ask this question. Why the OnePlus Community app requires mandatory permission to storage and media. If I intent to attach files / images then it's fine. But why always ?
  7. D1570344717096
    Froyo Oct 21, 2019
    D1570344717096 , Oct 21, 2019 :
    that's my point Alive...
    when a phone with smaller battery bought a couple of years ago delivers almost the same observed use in 1+7t, it makes me wonder what's more powerful other than display features... makes me wonder somewhere something is not aligned as required which I'm sure 1+ support will figure out and not let their family down.
    Especially when experienced by multiple users and claimed by 1+ of having a larger and more powerful battery, hardware.
  8. D1570344717096
    Froyo Oct 21, 2019
    I've seen an option to allow only when app is being used... that's a new permission setting I'm noticing on Android 10
  9. ks_oneplus
    Yes, that is for location access. I haven't seen that option for storage access.
  10. J1571231155310
    Cupcake Oct 21, 2019
    J1571231155310 , Oct 21, 2019 :
    I am not able to pair Bluetooth devices in 7T.. any suggestions/solution.. already tried system reset and cache clear tips but still the same..
  11. Alvie
    The Lab - OnePlus 5T Reviewer Oct 21, 2019
    Alvie , Oct 21, 2019 :
    As far as I know, it's like that for all apps. I don't think apps can use it in the background anyway so I wouldn't worry about it.
  12. K1571669791142
  13. sivaramav85
  14. K1571669791142
  15. Deepak_Sharma the great
    Eclair Oct 22, 2019
    D1570344717096 likes this.
  16. maheshkumar006
    Cupcake Oct 22, 2019
    maheshkumar006 , Oct 22, 2019 :
    I bought OnePlus 7t .battery drains fast even at 60hz .I get max screen time only 5 hours .FYI I am not a heavy user. is there any problem with battery or this is the maximum screen on time , I can get it from this device. I haven't switched to 90hz yet wondering how fast battery drains at 90hz if it cannot perform at 60hz. hope OnePlus is listening. should I replace my device? I did battery calliberation and wiped out cache on bootloader . I am really disappointed with this product. previously I have been using oneplus 2.
  17. maheshkumar006
    I am also facing similar issue . my battery drains fast even at 60hz.i get only 5 hours screen on time .
  18. D1570344717096
    Froyo Oct 22, 2019
    D1570344717096 , Oct 22, 2019 :
    well done!! Common day shots richly taken with a professional touch!!! keep up!![e]1f44d[/e][e]1f44d[/e][e]1f44d[/e]
  19. D1570344717096
    Froyo Oct 22, 2019
    I'd suggest to wait for the update OnePlus would come up with. there was already one where some display corrections are done. my screentime has improved a bit since then. Gamers would find it difficult with such quick battery drain. maybe that's why they brought the feature where you can charge while playing.
  20. Sai KrishnaD
    Gingerbread Oct 22, 2019
