73
[Q&A] The Ultimate OnePlus 7T Series Guide
  1. NickLarcher
    Cupcake Oct 24, 2019
    NickLarcher , Oct 24, 2019 :
    Tyvm
  2. ks_oneplus
    Gingerbread Oct 24, 2019
    ks_oneplus , via OnePlus 7T , Oct 24, 2019 :
    There is no specific headset that comes with 7T. You can buy type C headset separately. There is one available from OnePlus - type C bullets - you can buy that also.
  3. ks_oneplus
    This is a problem with many users. I also faced this issue. As a work around you can download the contacta app from Google and try setting up a contact photo there. The problem would get resolved. But again that's a work around.
    A1570638765540 likes this.
  4. D.M.kumar
  5. Threeline55
  6. ambysb
  7. balintbabics
    balintbabics , Oct 24, 2019 :
    I started to use this phone from Monday and I have a questions about it.
    There is any solution to make the Alarm sounds more quiter? Currently all the Alarm sounds are really load, even at the minimum Alarm volume level, literally I just felled out from bed when my alarm went off...
    agonyoflife likes this.
  8. K1570727884438
    K1570727884438 , Oct 24, 2019 :
    While sending pictures via WhatsApp to any contact , the app is not responding. At first, I think it may be any WhatsApp bug , so I updated the app , but still the issue is not resolved. Can u help me out resolving this issue? I am attaching a screenshot along with this query.
  9. GoodBetInVegas , via OnePlus 7T Glacier Blue , Oct 24, 2019 :
    Hi I am enjoying my newly received OnePlus 7T and getting to know it's features and at the same time getting to know the company behind it. so far so good except for finding information about setting up and using the dual SIM features. even when coming back to this thread to see if I had missed it, I don't see any mention about the fact that the phone has 2 sim capabilities.
    I'm new to the freedom of an unlocked phone, let alone one with these capabilities, but it does seem like an important item to include in the spec as well as in a feature or user guide.
    -David
  10. A1570638765540
    Cupcake Oct 25, 2019
    A1570638765540 , Oct 25, 2019 :
    Thank you... will try the same..
  11. Z1571967143025
    Z1571967143025 , Oct 25, 2019 :
    I am facing problem while playing game. I have downloaded NFS no limits ... Phone is not performing. system is getting slow and stuck in between game.
  12. agonyoflife
    Cupcake Oct 26, 2019
    agonyoflife , Oct 26, 2019 :
    Currently having the issue that even the lowest volume-settings are pretty loud on speakers.
    I previously had the OnePlus 6T and where the volume level for Alarm was in the 30-50% range it's now on the OnePlus 7T Pro even on minimum way to loud. Next step down is silent.
    What gives? Anyone has a workaround for that?
  13. Alvie
    The Lab - OnePlus 5T Reviewer Oct 26, 2019
    Alvie , Oct 26, 2019 :
    Thanks for the feedback, I'll include that! As far as I know OnePlus have been dual SIM since the OP2 so I must have somehow missed mentioning it. If you have any questions, feel free to ask!
  14. GoodBetInVegas , via OnePlus 7T Glacier Blue , Oct 26, 2019 :
    Thank you. I think it would be helpful for those like me that are new to OnePlus. As a side note, setting it up was remarkably easy and between the phone and Android 10, I didn't experience any of the problems mentioned by the beta testers. So far all is working well.
  15. D.M.kumar
  16. suneelkumar206
    Donut Oct 26, 2019
    suneelkumar206 , Oct 26, 2019 :
    I'm using OnePlus 7T with Airtel and Jio SIM in India, and I have noticed one peculiar thing that some of the apps like hotstar,moneycontrol and wynk music apps don't work with Airtel internet, although my connection strength is fine yet these apps won't respond on my Airtel network but when switching to Jio network these apps work fluently.
    please help me
  17. G SAI PAVAN
    G SAI PAVAN , Oct 26, 2019 :
    Hi
    Recently I bought One plus 7T phone. It was good and smooth UI. But recently my finger print scanner was popping out on irrelevant apps like on keypad and while scrolling apps the sensor area blocking the touch on the place. I really don't know why it was happening. Can any have a solution for this?
  18. Q1572080352104
    Cupcake Oct 27, 2019
  19. E1570008488656
    E1570008488656 , via OnePlus 7T , Oct 27, 2019 :
    can any one tell ?
  20. ks_oneplus
    Gingerbread Oct 27, 2019
    ks_oneplus , via OnePlus 7T , Oct 27, 2019 :
    What I understand these are India specific features are not yet rolled out. I also asked the same question about the possible timeline of getting these features.
    E1570008488656 likes this.
