5
[Q] Why does USB-C standard prevent Fast Charge?
  1. Yash98
    Gingerbread Oct 7, 2015
    Yash98 , Oct 7, 2015 :
    Why does the USB-C standard limit fast charge?
    EDIT:
    1) USB-C does not limit fast charge.
    2) OnePlus chose not to buy the license for Qualcomm proprietary fast charging technology and it requires hardware changes... So no software update will bring Qualcomm QuickCharging to OnePlus 2.
    3) No, Marshmallow will not enable fast charging on your one plus 2.
    4) 1+2 does not seem to have a proper USB-C port, its just a reversible connector which looks like an USB-C port. (Not sure, reading from the answers)
    4) OnePlus 2 supports USB-C based fast charging (see Nexus 6P fast charging for details) (not Qualcomm Quick Chage 1/2/3 and neither are turbo chargers compatible)
    5) It fast charges using Nexus 6P charger
    Gaurav Rohilla, weas, destutt and 2 others like this.
  2. Skf123
    Marshmallow Oct 7, 2015
    Skf123 , Oct 7, 2015 :
    It doesn't, the new nexus phones have USB type C and they are fast charge enabled.
  3. Ritxis
    Eclair Oct 7, 2015
    Ritxis , Oct 7, 2015 :
    Oneplus becomes too hot when charging, I think fastCharge will make it hotter.
    Deactivated User and jmhannz like this.
  4. riffraff81
    KitKat Oct 7, 2015
    riffraff81 , Oct 7, 2015 :
    asked and answered.
    sunilbagalur, Jamesst20 and Skf123 like this.
  5. vineet_30
    destutt likes this.
  6. LifelessLewis
    Jelly Bean Oct 7, 2015
    LifelessLewis , Oct 7, 2015 :
    It's the processor I believe. I don't think the SD810 supports it. Oneplus also said that they would've had to make the phone thicker to accommodate a larger USB module, although I don't think that's entirely true.
  7. nobelium76
    KitKat Oct 7, 2015
    nobelium76 , Oct 7, 2015 :
    I think the construction of the OPT itself is what limits fast charge.
  8. Skf123
    I believe all QC flagship chipsets since the 801 (maybe even before) have support for quick charge.
    810 specifications https://www.qualcomm.com/products/snapdragon/processors/810
    Quick Charge
    Qualcomm Quick Charge 2.0 technology, up to 3A out, supports Parallel Charging
    meatandy likes this.
  9. billq
    billq , Oct 7, 2015 :
    And I'm waiting for you to make your point .firstly op2 has no fast charge its clear at purchase time .second the nexus which a friend of mine got .is a dreadfull phone in real life you think.the op2 is buggy laggy ect get a nexus and wish for an op2
    mwayner and merewoodbebox like this.
  10. vineet_30
    vineet_30 , Oct 7, 2015 :
    N m happy with my OPT.it takes 2 hr 15 mins to fully charge from 1%.and easily lasts a day. i don't need a nexus.:cool:
    aenews, siddharth862, Hadas90 and 2 others like this.
  11. p51d007
    KitKat Oct 7, 2015
    p51d007 , Oct 7, 2015 :
    It doesn't, and, if you read the specs at the usb.org website, concerning usb-c you will find another "mis-statement" by Oppo/OnePlus. They DO NOT have a usb-c PORT, they have a usb-c "like" connector.
    A TRUE usb-c PORT has the plug-in-any-direction connector, AND a usb 3.1 PORT,
    which has the fast charge/data transfer.
    Once again, Oppo/OnePlus "stretched" the truth a bit claiming to be the first cellphone manufacturer with a "Usb-c" PORT by saying something like "The first to have usb-c"
    and leaving it at that, making everyone THINK they stuck to the usb.org, which makes the specs to make usb work around the world, specs for a TRUE usb-c device.
    http://www.usb.org/developers/usbtypec/
    Full specs are at the bottom of this page, where the usb 3.1 specs, that are used in the usb-c port are revealed.
    You just can't trust these people.
    matanwei and sunilbagalur like this.
  12. sid91
    Cupcake Oct 7, 2015
    sid91 , Oct 7, 2015 :
    OPT will have fast charging feature with Marshmellow update.
  13. billq
    That I'm thinking could speed up I can go from 1 to 30 in half hour which would give me about .almost a day lol.I've regularly gone 2 days with my op2 in normal use also the same with my opo
    merewoodbebox likes this.
  14. ozgur781sen
    Froyo Oct 7, 2015
    ozgur781sen , Oct 7, 2015 :
    Yes you are right I had Galaxy note 4 and have Galaxy s6 currently and both heat up when fast charging and I know that heat kills battery life so I try not to use it all the time except for emergencies.
    Once for some reason my note 4 got so HOT I couldn't touch the screen even when the phone was turned off.
  15. p51d007
    KitKat Oct 7, 2015
    According to Qualcomm, the 810 DOES support fast charging. Either Oppo/OnePlus, doesn't turn it on, or didn't license it to use it, or, they want to save it for the upcoming Oppo Find9, which is a more superior version of the OnePlus2. (and of course, sells for a lot more money)
    "The Snapdragon 810 fully supports Qualcomm® WiPower™ for Wireless Charging. The Qualcomm® Quick Charge™ 2.0 has been integrated for super fast battery charging."
  16. vineet_30
    how is that possible.I think we also need a quick charger for that and d license from qualcomm too. and Qualcomm Quick Charge technology is designed into a product by the manufacturer
  17. billq
    I suspect it will need a battery designed for that as well .like to wireless charge you need the battery with the airiel thing built onto and under the plastic battery cover
  18. WA_Bob
    WA_Bob , Oct 7, 2015 :
    It would be nice if they could switch it on with just a software command, but I believe that something has to be physically done to the processor before it will allow quick charging of the phone.
  19. vineet_30
    ya my opt last for 2 days with normal usage.and 1 day with heavy usage. and SOT of 5 to 6 hrs easily.
    billq likes this.
  20. sid91
    Cupcake Oct 7, 2015
    No dude android Lollipop does not support USB-C so OPT does not have fast charging feature yet. once OPT has Android M it OPT will have fast charging feature.
