QR code not working via OnePlus Nord
  1. V1558378348977
    Cupcake Jul 23, 2021
    TRT12345 likes this.
  2. Tokolozi
    Most Original Avatar Jul 23, 2021
    Tokolozi , Jul 23, 2021 :
    The Google lens button is right next to the shutter button. Due to android restrictions they can't add it directly in the camera anymore.
  3. #3
  4. SlackW_1993
    Jelly Bean Jul 24, 2021
    SlackW_1993 , Jul 24, 2021 :
    Since the latest updates you can now access Google Lens directly in your home screen Google Search Bar. Fast and easy ...
  5. MrFantastic22
    Gingerbread Jul 25, 2021
  6. Bellacampy
    Cupcake Jul 26, 2021
    Bellacampy , via OnePlus 9 Pro , Jul 26, 2021 :
    I have yet to test it, but even though I use my Google lens often, I went through my settings and found that camera and file permissions were still turned off for Google lens. Turned them back on again, so we shall see🤞🏽
  7. #7
  8. FreeRider7
    Cupcake Sep 21, 2021
    FreeRider7 , via OnePlus 7T Pro , Sep 21, 2021 :
    Im having the same problem. Can't scan any QR code with the camera app and I'm REALLY UPSET reading people suggesting to use Google Lens.
    The problem is in the camera app which I have always used to scan QR codes.
    Google lens is not a solution! It's just another way!!!
    OP bug fixing team MUST solve it. End of discussion!
  9. Tokolozi
    Most Original Avatar Sep 21, 2021
    Tokolozi , Sep 21, 2021 :
    In the latest camera API from Google they can't integrate it as before anymore. That's why there's a lens button right next to the shutter button now. You don't need to use a separate app, just a separate mode in the app.
    HoLeetihs and Sheppards like this.
