[Submitted] QUALCOMM Crashdump mode with OP7PRO on Android 10 OB1
  1. Computman
    Gingerbread Sep 4, 2019
    Computman , Sep 4, 2019 :
    Android 10 Open Beta installed
    QUALCOM CrashdumpMode appear doing nothing (modem crash)
    Be able to reboot with olume UP and Power but need to stay in Plane mode of the phone crash
    btsxbyz likes this.
  2. Emank
    Donut Sep 4, 2019
    Emank , Sep 4, 2019 :
    hey did you solve your issue? im having the same and dont know what to do...
    Ravneet007 likes this.
  3. Computman
    Emank
    hey did you solve your issue? im having the same and dont know what to do...​
    you can switch off using volume up and power button
    Then disable the location until next update or revert back to android 9 (you will have to wipe the device)
    I notice that I can enable the location without freezing since few hours. Don't know how many time it will work
  4. Emank
    Donut Sep 4, 2019
    hey I did the power button and volume up... and now it went back on without any problem... Hmmm
  5. G1510908046812
    Cupcake Sep 5, 2019
    G1510908046812 , Sep 5, 2019 :
    Same here, restarted the phone after a few minutes and now it is working. For how long is something different hopefully they gonna fix it.
    Emank likes this.
  6. Fuschy
    Gingerbread Sep 5, 2019
    Fuschy , Sep 5, 2019 :
    So this might be caused by the location setting? and turning it off fixes this?
  7. G1510908046812
    Cupcake Sep 6, 2019
    G1510908046812 , Sep 6, 2019 :
    just crashed again today and the location setting was off.
    Hopefully there will be an update shortly because I don't want to go back to android 9.
  8. Computman
    Gingerbread Sep 6, 2019
    Computman , Sep 6, 2019 :
    seems to be the workaround when it happen
  9. Fuschy
    Fuschy , Sep 6, 2019 :
    Hey are you switching between profiles? that seemed to have caused the issue for me. whenever I swapped, the crash happend a few minutes later
  10. G1510908046812
    Cupcake Sep 6, 2019
    no I never swapped between profiles on my phone, but it seems to happen by me when I've got lots of programs open in the back.
  11. RogerAnderson
    Donut Sep 6, 2019
    RogerAnderson , Sep 6, 2019 :
    Same issue here. It went through what I thought was an unstopable loop of crash, error screen and hard reboot which was so frequent I couldn't open an app before it crashed again. Then it started working again. Seemed to fail when I left the house so not sure if it's something to do with coming off the WiFi? Still crashes but less frequent now.
