Other QUALCOMM CRASHDUMP MODE
  1. Artemus.
    Nougat May 23, 2020
    Artemus. , May 23, 2020 :
    Your contacts are more than likely backed up (if not, you should've already done so) and are completely safe.
    U1575022819342 and Caomhin like this.
  2. U1575022819342 , via OnePlus Community App , May 23, 2020 :
    i did,but they said as my area comesin containment zone, they dont travel.
    thus i m with no option and clueless.
  3. Artemus.
    Nougat May 23, 2020
    You have an option: MSMDownloadTool (AKA "unbrick tool").
  4. #24
  5. Artemus.
    Nougat May 23, 2020
    The "risk/probability" is 100% but this is why you should've made a backup of your stuff long before this happened.
    U1575022819342, Batman360 and Caomhin like this.
  6. U1575022819342 , via OnePlus Community App , May 23, 2020 :
    yeah , i do agree, but i thought that there is option of oneplus cloud storage, so was reliable on it
  7. Artemus.
    Nougat May 23, 2020
    I don't have that option so I can't attest to its reliability but always make a backup with Google Drive just to be on the safe side.
  8. U1575022819342 , via OnePlus Community App , May 23, 2020 :
    so what is the solution through which i can get assurance thaf my data won't be lost,?
  9. Caomhin
    Lollipop May 23, 2020
    Caomhin , via OnePlus 6T , May 23, 2020 :
    Plug the phone into a PC or Laptop, see if you can access the files and transfer through that. Picture, DCIM folder, Documents, Download, Music, ebioks, etc all those folders.
    Also try booting in Safe mode by starting the phone using volume up and power button, press and hold both for 15 seconds and see if safe mode is an option in the Bootloader. If it manages to boot into that, then try backing up to the computer. Use the charging cable to connect via USB.
    U1575022819342 and Batman360 like this.
  10. U1575022819342 , via OnePlus Community App , May 24, 2020 :
    i am not able to access the Phone when i used cable to connect PC
  11. Caomhin
    Lollipop May 24, 2020
    Caomhin , via OnePlus 6T , May 24, 2020 :
    Which phone do you have, OP6 or OP6T?
  12. #32
  13. #33
  14. Caomhin
    Do a search on the Community here for Qualcomm Crash, there are numerous threads with possible suggestions, some work, many don't.
    If you don't find a Fix, the only solution is to try the steps below, but all data will be wiped from the phone, you may get some back such as contacts and photos, txt, apps etc if you synced your phone account to backup to Google Photos or Drive.
    The guide is in the link below, be sure to follow the one for your specific phone OP6. As I said, this will wipe your phone.
    Follow the instructions to use the MSMDownload Tool for Oneplus 6.
    https://www.thecustomdroid.com/oneplus-6-6t-unbrick-guide/
    Scroll down to view the Unbrick details and downloads.
    Download and use the Android version you want TO use to unbrick the phone with for OP6.
    Once you have the phone backup and running.
    Install OTA updates to get the most recent update.
    For those installing Android 9 only from the above guide.
    You must be on at least Android 9.0.9 in order to update to Android 10.
    You can then update to the Latest OOS Full Install update file.
    Either via OTA or check Latest release thread posts for update links. Or use 3rd party Oxygen updater from PlayStore.
    U1575022819342 and Artemus. like this.
  15. Infinn_8
    Donut May 24, 2020
    Infinn_8 , May 24, 2020 :
    I got that dumb 'Qualcomm CrashDump Mode' in my phone for no reason 29 days ago, I don't stunt with ROM or anything I'm a storage and backups kind of guy, I just overuse each device and that's it, it was about only 50MB free on my phone, I picked it to free space and it gave me CrashDumbbb mode with a glitch+sound. (The Wi-Fi got dead the other day it's 28 days and counting too) I can't work in 1.50GB limits, tried MSMDownloader tool when the error was displayed on screen but then it got into bootloop, I then found out on YouTube that those guys have their bootloader 'unlocked' before using MSMDownloader and I had mine 'locked' and the phone got hard bricked after two days of no use! It gets detected in PC only when it is discharged and does nothing when it's charged a bit, as per the characteristics! My Windows 7 got effed up while trying these things, currenlty at disturbed peace (as you can see from wordss) of 30th day at on Ubuntu! Just why the F I got that
    U1575022819342 likes this.
  16. Caomhin
    Have tried to decipher your rant, managed to get that you suffered the Crash dump issue, and the info supplied above in the posts are relevant to your issue.
    Retry them and see if it can help you.
    Also do a search in the Community here, as suggested above, for Qualcomm Crash, there a quite a few posts, some with suggestions, and maybe they may be able to help you with your issue.
    Otherwise contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  17. U1575022819342 , via OnePlus Community App , May 25, 2020 :
    did you try msmdownloafing tool?
    any other solutions?
    how can OnePlus team help here?
  18. U1575022819342 , via OnePlus Community App , May 25, 2020 :
    hi I tried using msm download tool.
    post the download is complete, yet i cannot see any sigh of phone turning on....
    is this because the battery must have not charged fully?
    #38
  19. U1575022819342 , via OnePlus Community App , May 25, 2020 :
    #39
  20. Artemus.
    Nougat May 25, 2020
    Artemus. , May 25, 2020 :
    Plug it in and see if it turns on.
    #40
