Other QUALCOMM CRASHDUMP MODE
  1. #41
  2. Caomhin
    Lollipop May 25, 2020
    Caomhin , via OnePlus 6T , May 25, 2020 :
    If you plug it in for an hour at least, it should then be near full charge.
    If still not power on with power button alone, press and hold Power & Volume up, it should boot to the Bootloader, if it does, select restart in here and see if it restarts normally.
    #42
    U1575022819342 and Artemus. like this.
  3. U1575022819342 , via OnePlus Community App , May 25, 2020 :
    you asking to plug in pc or to charge the phone?
    i tried pressing vol up n down + power button, but nothing is coming up
    #43
  4. Caomhin
    U1575022819342
    i tried pressing vol up n down + power button, but nothing is coming up​
    Leave it plugged in for an hour, you should see a charge icon on the screen when plugged in, even when switch off.
    After the hour, unplug it, then press the power button and Volume button at the same time keep pressed for 15 to 20 seconds until it starts to boot, you can now let go the buttons.
    #44
    U1575022819342 likes this.
  5. U1575022819342 , via OnePlus Community App , May 26, 2020 :
    hi caohmin,
    post the msmdownllad process..., the phone gets disconnected automatically where I cannot see any of port under PORTS in device manager.
    is this abnormal?
    as of now i have left the phone connected to PC
    #45
  6. Caomhin
    Lollipop May 26, 2020
    Caomhin , via OnePlus 6T , May 26, 2020 :
    Can you update the current status.
    1. Did you install an OOS build on to the phone with the MSMDownload tool
    2. Did it fully install
    3. Did you charge the phone
    4. Is the phone booting normally
    5. Is the Phone booting with Power & Volume up.
    6. Or what is the specific status of the phone currentky
    #46
  7. U1575022819342 , via OnePlus Community App , May 26, 2020 :
    1.yes
    2.yes
    3.i m not getting this , as when i m putting for charge (even for more than hour), there is nothing coming on the screen...
    4. once when download of msmtool shows complete, the phone doesnt show under ports., hence skeptical of booting
    5. volume buttons+ power button, isnt helping in anyway ...
    6.have kept phone on charging
    #47
    Caomhin likes this.
  8. Caomhin
    U1575022819342
    1.yes
    2.yes
    6.have kept phone on charging​
    That's very odd. Is it possible there is an issue with the Charger or charging cable. One more thing to check.
    Clean the ports on the phone, charger, and both ends of the USB cable with a fine dry toothbrush or non conductive wooden toothpick carefully. Just in case the connections are not being made.
    Make sure to plug it into an Electrical Wall socket.
    #48
  9. U1575022819342 , via OnePlus Community App , May 26, 2020 :
    dont think is the issue with slots, as earlier it detects phone when connected,only once it gets disconnected when download is complete.
    #49
    Caomhin likes this.
  10. #50
    Caomhin likes this.
  11. Caomhin
    Have no way to check it, but sometimes lint may get into the ports and the connection may not properly be made.
    Also make sure you try an electrical socket to charge the phone and not the laptop.
    If it still won't boot after an hour of charging in a socket then you will have to contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    #51
  12. U1575022819342 , via OnePlus Community App , May 27, 2020 :
    is it that even msm download tool has different version as per the O.S?
    and can be the issue?
    #52
  13. MK1992
    Donut May 27, 2020
    MK1992 , May 27, 2020 :
    Oneplus 6 is out of warranty i been using for 1 years + my country do not have any service center only 3rd party authorized by oneplus.
    I tried msm downloaded tool all steps completed successfully and still stuck at bootloop.Non-root phone.
    #53
  14. MK1992
    Donut May 27, 2020
    Same i also overuse it 😀... switching out oneplus
    #54
  15. MK1992
    Donut May 27, 2020
    Useless than ios at least have itunes to unbrick successfully
    #55
  16. Caomhin
    Lollipop May 27, 2020
    Caomhin , via OnePlus 6T , May 27, 2020 :
    MSMtool I linked to was for your phone model, so will have the correct OOS for your model
    #56
  17. #57
    Caomhin likes this.
  18. Caomhin
    Lollipop May 28, 2020
    Caomhin , via OnePlus 6T , May 28, 2020 :
    As I said, if still not working, contact OnePlus support directly, link is in previous post
    #58
    Artemus. and U1575022819342 like this.
  19. #59
    Caomhin likes this.
  20. Infinn_8
    Donut Jun 18, 2020
    Infinn_8 , Jun 18, 2020 :
    Thanks for your answers but I had used MSMDownloading tool too, I mentioned it above..
    Sorry for replying late, I just forget because of this bricked phone stress!
    Went to service center as the lockdown ended, they were telling it was a 'motherboard' issue, I won't spend 20k on a motherboard of a 40k phone, plus it was sotfware's issue which got crashed and now it's hard bricked, they said that the phone isn't turning on and it needs to get its motherboard replaced, they might have checked the phone by connecting to PC after a full charge, but in my every latest case, the phone gets detected only in the lowest charging(in almost dead battery, not touched for a day).. Having a secondary - middleman warranty ending on 23rd of June now, which started after the OnePlus' 1 year warranty, in which the guy said this covers motherboard issue too, just fix this broken battery cover issue you have from service center and then check back for our site if motherboard issue comes up..
    All I want to say is OnePlus sucked at power usage now, (even when the usage was normal when shit happened).
    And yes, the 'talk to customers' staff didn't seem quite professional too for understanding the issue(s).
    #60
