[Question] Most stable n fast lollipop rom for OPO
  1. jaferiqbal
    Ice Cream Sandwich Aug 11, 2015
    jaferiqbal , Aug 11, 2015 :
    Which is the most stable,smooth,least buggy,good battery bakcup rom for oneplus one ?
    Currently on calkulins battery saver 3.2 lollipop 5.0.2 rom
  2. anandyesudian
    anandyesudian , Aug 11, 2015 :
    That is the best for now. Mainly because of its good battery life. Even i have downgraded to the same.
  3. jaferiqbal
    Don't know why I am not getting much backup as expected.
    Also facing some problems with my network(3g internet) , random reboots etc
  4. anandyesudian
    I get good backup. Around 3 days (ya I dont get time to use the phone). It is on wifi always no data. But i have used 3G before with this ROM. No problems. Try a fresh install (backup). Maybe u dirty flashed.
  5. jaferiqbal
    Clean flashed it... Network was constantly going into emergency calls only
    So i flashed oxygen os modem.. It solved the problem. But facing other problems now.
    Yeah battery is good on WIFI when i am home.but using 3g just gives a normal backup 3-4 hours sot
  6. anandyesudian
    Maybe something went wrong with the modem. Change it again. I did not change the modem.
    Search google for oneplus one battery saving tips. try them.
    Still problems then check what process is eating up battery.
  7. emiljosthomas
    Eclair Aug 11, 2015
    emiljosthomas , Aug 11, 2015 :
    Respected Sir,
    I bought the OnePlus One today from Flipkart in India.
    The phone i received was in very good condition and it sure is a great phone.
    But the software I found on the phone was Android 4.4.4 Kitkat and running on Cyanogen 11
    Im writing this email to know weather i will be getting any update for my phone.
    Will I be getting an update to cyanogen 12 or will I be getting Oxygen OS.
    Do let me know.
    the phone shows manufacturing date of July 7 2015.
  8. zeus.01.01.01.01
    Lollipop Aug 11, 2015
    zeus.01.01.01.01 , Aug 11, 2015 :
    well i haven't tried calkulins yet ...
    but exodus is working best for me !!
    Nidhin Raj and jaferiqbal like this.
  9. zeus.01.01.01.01
    you will get update soon ... and if you lack patience then simply go to settings>>about phone >> software update and keep checking for updates until you get notified of one .. there will be an update to CM 11 05Q first ... you will receive CM12 update after you have updated to it ..
    and if you really really lack patience then simply download CM12 file and flash it .(you don't need to unlock bootloader or any other stuff for that )
  10. emiljosthomas
    Eclair Aug 11, 2015
    right now it runs cyanogen 11.0-XNPH05Q
    BUT GETTING UPDATE FOR XNPH05Q.which prepares my device for cyanogen 12..
    thnx buddy..
    also one more thing..
    is it good to upgrade to cyanogen 12 or just stick with cyanogen 11
  11. zeus.01.01.01.01
    its your call !!
    CM11 has better battery life ... but if you really want lollipop then you can go for CM12 ..
  12. jaferiqbal
    Just stick to cm11for a month until lollipop gets more stable and bug free.
    Cm11 is great plus you get to experience both
  13. jaferiqbal
    Which version you using ?
    Any known bugs ?
  14. jaferiqbal
    Already checked , most apps greenified
    Nothing suspicious in wakelock detector.
    It's working alright now...
    If it gives problem again I"ll flash exodus rom
  15. aryansashi
    Jelly Bean Aug 11, 2015
    aryansashi , Aug 11, 2015 :
    Link for the rom pleasr
  16. jaferiqbal
