11
[Quick Fix] Google Messages Battery drain warning issue via OnePlus 9 Pro
  1. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Jul 21, 2021
    Nipu_1998 , via OnePlus 9 Pro , Jul 21, 2021 :
    Hi,
    After the latest google messages update, many of the OnePlus 9 series users are reporting that the system gives battery drain warning for the messages app.
    The issue was a result of the battery consumption optimisation of the messages app in the latest update.
    Here's how to fix it :
    1. Open settings
    2. Go to apps and notification settings
    3. Select the messages app from the app list
    4. Click on the three dot menu in the upper right corner
    5. Click on un-install all updates.
    Make sure to turn off the auto update feature in the playstore too.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 21, 2021
    Navdeep_Malik, Tokolozi and McJader like this.
  3. McJader
    Marshmallow Jul 21, 2021
    McJader , Jul 21, 2021 :
    Saved👍
  4. Nipu_1998
    Dresa91 and McJader like this.
  5. Dresa91
    Nipu_1998 likes this.
  6. gautamthapar
    The Lab Reviewer - OnePlus TV U1S Jul 22, 2021
    Navdeep_Malik, Nipu_1998 and McJader like this.
  7. McJader
    Marshmallow Jul 22, 2021
    McJader , Jul 22, 2021 :
    What's the version?
    Dresa91 likes this.
  8. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Jul 22, 2021
    Nipu_1998 , via OnePlus 9 Pro , Jul 22, 2021 :
    Sure🙌
    Dresa91 likes this.
  9. Goku003
    Eclair Jul 22, 2021
  10. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 22, 2021
    Dresa91 , Jul 22, 2021 :
    Three posts above yours:
  11. ady_agar
    Froyo Jul 22, 2021
  12. gautamthapar
  13. KamalHasthan
    Cupcake Jul 28, 2021 at 6:52 AM
  14. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 28, 2021 at 6:54 AM
  15. KamalHasthan
    Cupcake Jul 28, 2021 at 6:55 AM
  16. Raunak1601
    Cupcake Jul 29, 2021 at 10:52 AM
    Raunak1601 , via OnePlus 9R , Jul 29, 2021 at 10:52 AM :
    I'm facing same issue on my 9R. No updates have fixed it. Same device is being used by my friends, and no such issues have been encountered by them. I'm trying this uninstalling the updates. Will update later if the problem is resolved or not.
  17. M1604771611906
    Cupcake Jul 29, 2021 at 3:01 PM
    McJader likes this.
