2
Quick Settings Toggle
  1. Hyrokun1
    Eclair Feb 13, 2018
    Hyrokun1 , Feb 13, 2018 :
    Hi there,
    One thing i noticed which i used to have on the stock Android (nexus 6p) was when you pull down the quick settings, if you clicked on WiFi for example, there would be 2 things you could do..
    1. Toggle wifi on/off
    2. Look at the list of wifi
    Just some feedback on a feature i really miss on the OP5T. Wondering whether this will come soon or is planned to?
    Could also be used for the Bluetooth setting too
    wizat and zzinnia like this.
  2. Waveform Modifier
    Marshmallow Feb 13, 2018
  3. MentalDraco
    MentalDraco , Feb 13, 2018 :
    You can still do that... Tap it to toggle WiFi on/off and long press it to open the WiFi list.
  4. Hyrokun1
    Eclair Feb 13, 2018
    Ah okay, that works too but was hoping to do it without opening settings!
  5. MentalDraco
    Well you don't have to open settings, long pressing the WiFi icon will take you to the WiFi list, yes that list is in settings but you are taken directly to it.
    G_Paul_H_tsHU likes this.
  6. G_Paul_H_tsHU
    Eclair Feb 14, 2018
    G_Paul_H_tsHU , Feb 14, 2018 :
    you might need to move the wifi icon to the top row of quick settings but the above posts are correct.
    pull down once and long press the wifi icon
  7. Hyrokun1
    Eclair Feb 14, 2018
    Hyrokun1 , Feb 14, 2018 :
    MentalDraco
    Well you don't have to open settings, long pressing the WiFi icon will take you to the WiFi list, yes that list is in settings but you are taken directly to it.​
    Not opening it manually but like having the application open (and it opens a new process which needs to be swiped closed)
    Im lazy but its the small things
