136
Raffles 2019/05/15: Launch Event Goodie Bag & OnePlus Bullets Wireless 2
  1. Ankitc1998 Eclair May 21, 2019
    Ankitc1998, May 21, 2019 :
    I didn't find any exclusive store in kanpur, and as far as I can see, it is in-stock online.
    Try ordering online.
    There might be different results for different pin codes.
  2. D1548690773335 Cupcake May 21, 2019
  3. D1548690773335 Cupcake May 21, 2019
  4. Ankitc1998 Eclair May 21, 2019
    Ok , what u asked earlier was "where can I buy them in India", so I thought you asked for the bullet 2, but the screenshot you've sent is of bullet(that's the first launched wireless in-ear earphones/bullets).
    Extra info:
    1. If you have a chroma nearby just go and try asking them for the bullet as chroma is officially partnered with Oneplus to sell their products offline.
    2. Find a store which deals in Oneplus products offline and buy it from there.
    3. If both of the above points dont work, wait for the online store bring the bullets back in-stock.
    If I helped, please like all the posts that I have posted related to your question.
    kudo's [e]270c[/e]️
    D1548690773335 likes this.
  5. Christopher Doherty Gingerbread May 21, 2019
  6. E1558154600593 Cupcake May 22, 2019
  7. Ramesh_Bhanushali Froyo May 22, 2019
  8. Ankitc1998 Eclair May 22, 2019
    Ankitc1998, May 22, 2019 :
    You have 96 hours and 20 minutes from now to enter.
    After that the entry period will be closed!
    Like this post if helped!
    kudo's [e]270c[/e]️
  9. devesh darji Gingerbread May 22, 2019
    devesh darji, May 22, 2019 :
    what's the error and which mobile and version of software you are using. Only then I can help
  10. G_Radha_P_epYX Donut May 22, 2019
    SHIV ROCK likes this.
  11. Dark Devil Gingerbread May 22, 2019
    Dark Devil, May 22, 2019 :
    it's available on OnePlus.in
  12. Dark Devil Gingerbread May 22, 2019
    5 post 1 point Max u can earn 5 points
  13. Dark Devil Gingerbread May 22, 2019
    26th may 9:30 am is last time to participate and draw will be on 26 may 10:00 am
  14. Dark Devil Gingerbread May 22, 2019
    Max 5 points per day
  15. jonbosticshep Cupcake May 22, 2019
  16. Reggers13 Froyo May 23, 2019
  17. Ankitc1998 Eclair May 23, 2019
    Ankitc1998, May 23, 2019 :
    26th May 2019 at 10:00 Am
    Like if helped!
    kudo's [e]270c[/e]️
    Reggers13 likes this.
  18. Faguni Donut May 23, 2019
  19. Ankitc1998 Eclair May 23, 2019
    Try opening it on the browser, I had the same issue when opening through the community app
    Procedure:
    1. Press the menu option on the top right corner.
    2. Select the first option(open in browser)
    3. Sign-in and register your entry.
    Wish u luck!
    Like if I helped!
    kudo's [e]270c[/e]️
    Faguni likes this.
  20. Faguni Donut May 23, 2019
    Faguni, May 23, 2019 :
    Thanks
    Ankitc1998 likes this.
