rainbow coloured lines on screen
  1. shaikhriyaz25
    Cupcake Oct 27, 2017
    shaikhriyaz25 , Oct 27, 2017 :
    I am seeing a few small faint rainbow coloured lines on my screen especially on a white or bright background. Are these due to scratches on the screen protector or is it some display issue. I am using the pre-applied screen protector.
  2. Budruel
    KitKat Oct 27, 2017
    Budruel , Oct 27, 2017 :
    Take a picture so we can see it. Otherwise it might even be that you have gone out partying and consumed psychotropics so you would see the rainbow and underneath a unicorn mounted by an elf.
    Lavin A. likes this.
  3. Lavin A.
    Ice Cream Sandwich Oct 27, 2017
    Lavin A. , Oct 27, 2017 :
    If they aren't perfect straight lines spanning the entire display, then yeah, they're probably from the scratches on the screen protector.
  4. shaikhriyaz25
    Cupcake Oct 28, 2017
    shaikhriyaz25 , Oct 28, 2017 :
    yes they aren't straight nor do they cover the entire display. They are around 1 cm in length
  5. shaikhriyaz25
    Not visible in the pictures because as I said earlier they are faint
  6. G_naveen_iglesias_dnsd
    Donut Oct 28, 2017
  7. Sridhar Ananthanarayanan
    Lollipop Oct 28, 2017
    Sridhar Ananthanarayanan , Oct 28, 2017 :
    yeah. most likely (99%) screen protector. change it.
  8. shaikhriyaz25
    ok thanks for the help
  9. C1573469380444
    Cupcake Nov 11, 2019
    C1573469380444 , Nov 11, 2019 :
    I am also facing the same issue with my One plus 7 pro automatically. I dont use screen protector. Please help as it is also causing fingerprint password to not work properly
  10. Waveform Modifier
    Marshmallow Nov 11, 2019
    Waveform Modifier , Nov 11, 2019 :
    Wrong forum
