ram management issue
  1. Imran Hussain
    Cupcake Sep 10, 2019
    Imran Hussain , Sep 10, 2019 :
    i have one plus 6t and one plus 7 bt the issue i m facing in op7 is ram management its too aggressive plz solve this problem ......as it annoyse me while switching between 3 4 apps
    EduardoUS likes this.
  2. Budruel
    KitKat Sep 10, 2019
    Budruel , Sep 10, 2019 :
  3. Imran Hussain
  4. sushanth_goud
    Eclair Sep 10, 2019
    sushanth_goud , Sep 10, 2019 :
    Go to Settings>>System>>Recent App Management>>Enable Normal Clear and not Deep Clear. Check if having same issue.
  5. G_Mohamed_Rezeem_GyXw
    Froyo Sep 10, 2019
    G_Mohamed_Rezeem_GyXw , Sep 10, 2019 :
    yeah by default itself( normal clear )
    and still I have issues in ram management op 7
    6gb variant disappointing.
  6. Ever7p
    Froyo Sep 12, 2019 at 1:17 AM
    Ever7p , Sep 12, 2019 at 1:17 AM :
    I would turn off battery optimization for you most used apps. See if that helps. Also list any steps you have taken to solve the issues.
  7. G_Mohamed_Rezeem_GyXw
    Froyo Sep 12, 2019 at 8:36 AM
    G_Mohamed_Rezeem_GyXw , Sep 12, 2019 at 8:36 AM :
    yeah I have turned on battery optimisation for many apps.
    will that effect in ram management??
  8. Kirakichi
    Jelly Bean Sep 12, 2019 at 2:56 PM
    Kirakichi , Sep 12, 2019 at 2:56 PM :
    disable adaptivr battery, will solve ur problem.
    i notice no battery drain with that disabled, imo that feature saves probably only 2-3%/100% charge which aint worth i guess for what it sacrifices.
  9. G_Mohamed_Rezeem_GyXw
    Froyo Sep 12, 2019 at 3:01 PM
    G_Mohamed_Rezeem_GyXw , Sep 12, 2019 at 3:01 PM :
    so should I disable adaptive battery??
    will this helps in ram management??
    and what's the connection between ap battery and ram management
  10. Kirakichi
    Jelly Bean Sep 12, 2019 at 3:02 PM
    Kirakichi , Sep 12, 2019 at 3:02 PM :
    from my test, the apps stay in background even of u put phone off for 5-10min, it wont kill the app.
    do like mine, then restart phone and use it for a day, see if its as u wanted it to be.
    EDIT: This configure does not touch my apps anymore, apps will only close if the ram management wants, no more minding too much to put apps to sleep to save battery if not used or if alot apps is in use.
    It helps me alot to not miss any apps notification too, and battery consumption is untouched!
    and what's the connection between ap battery and ram management​
  11. G_Mohamed_Rezeem_GyXw
    Froyo Sep 12, 2019 at 3:06 PM
    G_Mohamed_Rezeem_GyXw , Sep 12, 2019 at 3:06 PM :
    ok will this effect battery life???
    because now I'm getting 7.15 -8.5 hrs of sot with normal usage and with heavy usage I'm getting 6.30 sot
  12. Kirakichi
    Jelly Bean Sep 12, 2019 at 3:08 PM
    Kirakichi , Sep 12, 2019 at 3:08 PM :
    No, it wont.
    it doesnt for me despite i have alot apps installed, try it for one day and come back to here, tell me how it is, you will see your phone is alot better in terms of ram management, you can now fully benefit your 6/8/12gb ram phone.
    my phone is 12GB ram version
  13. G_Mohamed_Rezeem_GyXw
    Froyo Sep 12, 2019 at 3:11 PM
    G_Mohamed_Rezeem_GyXw , Sep 12, 2019 at 3:11 PM :
    oh 12 gm ram/ 7pro [e]1f525[/e][e]1f525[/e]
    I'm using op7 6gb variant [e]1f60a[/e]
    ok bro I will do it and come here after 2 days [e]1f60a[/e]
    Kirakichi likes this.
  14. Kirakichi
    Jelly Bean Sep 12, 2019 at 3:14 PM
    Kirakichi , Sep 12, 2019 at 3:14 PM :
    looking forward to hear back from u in 1-2 days :)
  15. G_Mohamed_Rezeem_GyXw
    Froyo Sep 12, 2019 at 3:56 PM
  16. Kirakichi
    Jelly Bean Sep 12, 2019 at 4:03 PM
    Kirakichi , Sep 12, 2019 at 4:03 PM :
    dont listen it, try like i said 1-2 days.
    if your not happy then u can switch it on back anytime u want.
  17. G_Mohamed_Rezeem_GyXw
    Froyo Sep 12, 2019 at 9:04 PM
