Ram management issues
  1. Ranjithsmart
    Jelly Bean Sep 21, 2019
    Ranjithsmart , Sep 21, 2019 :
    I am having oneplus 7 6gb, 128 gb variant. When i keep pubg minimized and Asphalt 8/angry birds 2 on present screen, pubg game automatically gets closed. I have also tried gaming mode on and off and ram boost option on and off, (nothing worked) . Whenever i see my running services (cached) in developer options only 600-700 mb is free. My doubt is, having 6gb of ram for oxygen os is not enough? How to keep multiple apps in background alive?
    JAFFEERA likes this.
  2. B_Wrath
    Marshmallow Sep 21, 2019
    B_Wrath , Sep 21, 2019 :
    By locking them in the recent menu.
  3. Ranjithsmart
    Just now tried that dude. It can't manage.
    P1565587480317 likes this.
  4. B_Wrath
    Turn off advanced battery optimizations.
  5. Ranjithsmart
    B_Wrath
    Turn off advanced battery optimizations.​
    This time i turned off all advanced optimizations options , i selected pubg, Asphalt 8/angry birds 2 as don't optimize battery, locked the both apps in recent menu, and turned off gaming mode.(nothing helps me out)
    G_Ravi_Prajapati_WcwQ likes this.
  6. DA7801
    Honeycomb Sep 21, 2019
  7. Budruel
    KitKat Sep 21, 2019
    Budruel , Sep 21, 2019 :
    To minimize a game like PUBG and play others, you would probably need more than 6GB of RAM.
    There are more services that are using RAM.
    You should have thought about it before choosing the 6Gb variant.
    F_Vijay_Kumar_HUqj likes this.
  8. Ranjithsmart
    Jelly Bean Sep 22, 2019
    Ranjithsmart , Sep 22, 2019 :
    My old oneplus 3T can manage pubg in background and mobile like Samsung and apple having very least size of ram can clearly manage multiple apps in background. Yesterday i searched answer for this problem in oneplus community,most of the people having the same issues. I am having oneplus 6T with 8gb of ram and whats the fun part is, In running services (cached) it is also having only 700-900 mb of free space. After Android 10 rollout i am going test again, let's see whether we have an improvement [e]1f609[/e].
  9. F_Vijay_Kumar_HUqj
    Froyo Oct 3, 2019
    F_Vijay_Kumar_HUqj , Oct 3, 2019 :
    if you don't know about Rams or phones just don't reply whichever comes to your mind. 6gb of ram is more than enough to keep Pubg or other apps in Cache memory. I've used one plus 5 with 6gb Variant and my other friends are also using op6t etc with 6gb ram. no one is facing as aggressive as One plus 7 series guys are. Seriously there is a problem in one plus 7pro and 7 as well. Ram management sucks.. Now research on this if you need and then comment.
    Thanks.
  10. F_Vijay_Kumar_HUqj
    Froyo Oct 3, 2019
    by the way it is not only with Pubg, other payment apps and UPI related also has same issues . once you get OTP to enter, if you go back and check the OTP and return back to enter it in UPI app, app get reloaded and it turns out to be nothing event happened. This is happening in one plus 7 Pro.
  11. Ranjithsmart
    Jelly Bean Oct 3, 2019
    Ranjithsmart , Oct 3, 2019 :
    Have anyone facing the same ram management issue in Android 10.I didn't receive the update yet.
  12. G_Ravi_Prajapati_WcwQ , via OnePlus 7 Pro , Oct 12, 2019 :
    bro i have 7 pro and im facing that problems.. if your problem solved soo... plz plz and me..
  13. Ranjithsmart
    Jelly Bean Oct 12, 2019
    Ranjithsmart , via OnePlus 7 , Oct 12, 2019 :
    Oneplus 7 pro is also having other major problems like
    it causes delay in attending calls and end calls. I think this ram management issues and other major bugs will be solved in android q update. Lets hope for the best. [e]1f601[/e][e]270c[/e]️
  14. Ranjithsmart
    Jelly Bean Oct 13, 2019 at 7:48 PM
  15. Dontsh00tmesanta
    Cupcake Oct 14, 2019 at 7:06 PM
    Dontsh00tmesanta , Oct 14, 2019 at 7:06 PM :
    whered u go to do that
  16. Dontsh00tmesanta
    Cupcake Oct 14, 2019 at 7:07 PM
  17. Ranjithsmart
    Jelly Bean Oct 14, 2019 at 7:08 PM
  18. Ranjithsmart
    Jelly Bean Oct 14, 2019 at 7:09 PM
  19. Dontsh00tmesanta
    Cupcake Oct 14, 2019 at 7:15 PM
    Dontsh00tmesanta , Oct 14, 2019 at 7:15 PM :
    Both adaptive battery and sleep standby optimization are turned off. Referring to those?
  20. Ranjithsmart
    Jelly Bean Oct 14, 2019 at 7:17 PM
    Ranjithsmart , via OnePlus 7 , Oct 14, 2019 at 7:17 PM :
    Mm yes.... I would like to know about your android version,device name and variant.
