Random ads while using phone via OnePlus 6T
  1. Guru bhoyar
    Cupcake Oct 16, 2021
  2. camohan
    Assistant Head Moderator Assistant Head Moderator Oct 16, 2021
    camohan , Oct 16, 2021 :
    Hi there, the random ads are being seeded by some app.
    Whenever you see an add, try see if you can long press to identify which app is sending it.
    Uninstall the app to get rid of it.
    Sometimes the app name is blank. You can also use this app to identify which app is sending annoying ads
    https://play.google.com/store/apps/details?id=popup.ads.detector
  3. Guru bhoyar
    camohan likes this.
  4. G_Mark_Dunn_JMmj
    Froyo Oct 27, 2021
    G_Mark_Dunn_JMmj , Oct 27, 2021 :
    Sometimes you can go to settings - apps and the one that sent the ad will be first on your most recent apps. It sent the ad so it shows as must recent app used. Good luck
  5. psygarden
    OnePlus TV Product Ninja 2021 Oct 27, 2021
