3
Random frame drops via OnePlus 6T
  1. xXDetonatorXx
    Froyo Jan 26, 2020
  2. Artemus.
    Nougat Jan 26, 2020
    Artemus. , Jan 26, 2020 :
    Not gonna mention the apps used?
    Caomhin and Bilalazeem54 like this.
  3. xXDetonatorXx
    Froyo Jan 27, 2020
    Q1585607371250 and Fatumboy like this.
  4. Artemus.
    Nougat Jan 27, 2020
    Artemus. , Jan 27, 2020 :
    The "home screen" is an app called a "launcher".
  5. xXDetonatorXx
    Froyo Jan 27, 2020
    Q1585607371250 likes this.
  6. Artemus.
    Nougat Jan 27, 2020
    Android 10 has problems. All I can suggest is to either purge the cache/data or do a complete wipe if you haven't already.
  7. Fatumboy
    Froyo Mar 30, 2020
    Fatumboy , via OnePlus 7 Pro , Mar 30, 2020 :
    I have the same problem as the comments above...
    I wrote to the developers, tried all possible ways, but the problem remains and there is already more than one update and the problem is not fixed ...
    The phone just lays down and skips frames when scrolling in almost all applications.... It can't be tolerated...
    You can write in the following branches if you have the same problem. https://forum.xda-developers.com/oneplus-7t/help/lag-scroll-7t-series-android-10-t4012171.
    https://forums.oneplus.com/threads/...g-oxygen-10-bug-on-all-7t-7tpro-7pro.1197726/
    xXDetonatorXx likes this.
  8. Caomhin
    Lollipop Mar 30, 2020
    Caomhin , via OnePlus 6T , Mar 30, 2020 :
    This is a 6 series thread, you have 7 series according to your sig, different hardware. Discuss in 7 series thread
    Artemus. likes this.
  9. bojantomic
    Honeycomb Mar 30, 2020
    bojantomic , via OnePlus 6T , Mar 30, 2020 :
    Yeah, this is a known issue which is yet to be fixed, unfortunately.
    They mentioned multiple times that they fixed it with the latest updates, but it still shows up, just a bit less.
  10. Q1585607371250
    Cupcake Mar 30, 2020
    Q1585607371250 , Mar 30, 2020 :
    I bought the 6t over 3 months ato,no problema for the First 2 weeks but now Is full of bugs,mamy times Is heating even of i dont play games and sometimes i have to restart It cause the touch screen doesn t work well...I really regret i bought this phone and i hope this will help people understand how a brand like oneplus isn't good like a Samsung or Iphone.etc..
    Sorry for my bad english.
  11. Artemus.
    Nougat Mar 31, 2020
    Artemus. , Mar 31, 2020 :
    Did you format after updating to A10?
    Caomhin likes this.
  12. Q1585607371250
    Cupcake Mar 31, 2020
    Q1585607371250 , Mar 31, 2020 :
    no i didn t and i wont.
    They have to solve the problema with a upgrade,cmon i spend 500€ can i use the phone without format It After every upgrade?
  13. Artemus.
    Nougat Mar 31, 2020
    After every major version update (9 to 10) it's highly recommend to wipe the device to reduce bugs brought on by dirty-flashing. You have to do with every phone. A clean phone runs better than one bogged down by years of stuff.
    Caomhin likes this.
  14. Q1585607371250
    So i have to save all my data then format, isn't there any other solution?
    You know if they will release new updates ?
  15. Artemus.
    Nougat Mar 31, 2020
    Yep, that's generally the best way to reduce the amount of bugs. And yes, there will be new updates but the pandemic is kind of making it more difficult.
  16. Q1585607371250
  17. oneplusknusper
    Eclair Jul 3, 2020
    oneplusknusper , Jul 3, 2020 :
    I found the solution to this problem - on my 6T (128/6 mirror black on OOS 10.3.4), a simple uninstall of the official Reddit-app solved it. Haven`t experienced the dreadful frame rate-drops ever since.
  18. Archit@123
    Gingerbread Jul 5, 2020
    Archit@123 , via OnePlus 6T , Jul 5, 2020 :
    Q1585607371250
    I understand thank you for reply. [e]1f44d[/e]🏻
    No need to factory reset for this issue this issue is present from andriod 10 even on one plus 6t I have done factory reset even used msm tool to try but this is oxygen os problem not the launcher issue bcuz I have tried Nova launcher and Microsoft launcher still got fps drops while scrolling randomly frequency is low but yes.
    One plus needs to fix this issue already reported the bug but they didn't even replied.
    Fatumboy likes this.
