Random sound
  1. Kristijan94
    Cupcake Jul 10, 2019
    Kristijan94 , Jul 10, 2019 :
    Hi,
    after last update I am getting random sound on my phone, i dont get any kind of notification when it beeps, i dont have any app to use that sound. Its heapend while I use it and while I dont use it, does anyone have solution for this??
    I restarted it(not factory reset, just rebooot), whipe cash partition and nothing helped.
    Tnx in advance.
    J1571567505541 likes this.
  2. the_o2
    Marshmallow Jul 11, 2019
    the_o2 , Jul 11, 2019 :
    Try to boot into Safe mode and check,
    If nothing like this happening there that's means any app is doing that,
    If sound coming there too then better to do a factory reset or call OnePlus support.
  3. Kristijan94
    Cupcake Jul 11, 2019
    Kristijan94 , Jul 11, 2019 :
    Thank you, I will try that, I will write after doing that.
    the_o2 likes this.
  4. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 11, 2019
  5. Kristijan94
    These are last updated apps, and I dont have "True Caller", this didnt started just after update of system or apps it is started later, and Is not NFC.
  6. Kristijan94
    Cupcake Jul 16, 2019
    Kristijan94 , Jul 16, 2019 :
    hey guys, i deleted some apps but that didnt help, sound was still there so i factory reset phone, not from settings but from booting menu. I instaled all apps I had before except WhatsApp and for now its looks is ok, Inhope that will stay like that.
  7. N1571162332854
    Cupcake Oct 15, 2019
    N1571162332854 , Oct 15, 2019 :
    There's a random beep or sound that keeps coming from my phone. At first, it was coming when I was not using it and it was just lying, so at random it used to make that sound. But from past 3 to 4 days while even using it, it has started to ping with that sound. I've recorded that beep as well. But no idea how to share it and where to share it.
    Please resolve this issue of mine. It's making me go crazy.
  8. Meangate
    Donut Oct 16, 2019
    Meangate , Oct 16, 2019 :
    I have the same i think. Every time I go in to messenger and write to someone I'm hearing Indian flute music... How can I get it offf
  9. Kristijan94
    Cupcake Oct 22, 2019
    Kristijan94 , via OnePlus 6T , Oct 22, 2019 :
    I had same problem, my phone played random sound like notification, but that sound wasnt in offered sounds when i try to set sound for notifications. What I did is factory reset from boot menu, and after that I didnt have that problem, the only app I didnt install after facotory reset is "Whats App" , I cant tell that was the problek but factory reset helped for sure.
  10. bennyboy111
    Cupcake Oct 29, 2019
    bennyboy111 , Oct 29, 2019 :
    I've been hearing some weird and strange sounds the last 24 to 36 hours. Didn't think it was my phone though, thought it was the tv or something playing in the background. Will definitely keep an ear out for this, glad I found this post.
