4
random vibrations
  1. #21
  2. G_vinay_baseganni_AzBL , via OnePlus 5T , Nov 26, 2019 :
    delete cache of each app going into settings. then do wipe cache in bootloader by pressing volume down and power button for ten seconds. it's solved for me.
  3. V1573584599664 , via OnePlus Community App , Nov 26, 2019 :
    I already tried it many times but it is not a solution. If this way is the best one, I dont understand why end user has to delete cache. I guess oneplus team doesnt have any solution.
  4. Waveform Modifier
    Marshmallow Nov 26, 2019
    Waveform Modifier , Nov 26, 2019 :
    Have you even report it to OnePlus? Are they aware of this problem of your?
  5. V1573584599664
    Donut Nov 26, 2019
    V1573584599664 , Nov 26, 2019 :
    They asked me to replace another one at a tmobile store and i exchanged it for anothet device 2 times.
  6. Waveform Modifier
    Marshmallow Nov 27, 2019
    Waveform Modifier , Nov 27, 2019 :
    Maybe you need to talk to them again or maybe do some investigating on the apps you are using. There isn't too much the user community can suggest at this point.
  7. L1578070483980
    Cupcake Jan 3, 2020
    L1578070483980 , Jan 3, 2020 :
    Had the same issue, turned off NFC and it resolved. I have an ewallet on the back of my phone so chip cards may have been messing with NFC sensor.
  8. V1573584599664
    Donut Apr 19, 2020
  9. ajk99
    Cupcake Oct 12, 2020
    ajk99 , Oct 12, 2020 :
    It was an NFC problem for me - NFC contact makes the phone buzz even when on Do Not Disturb. It started when I changed the position of some contactless cards in the phone cover. It turns out the one I use to get into the carpark is pretty 'agressive/sensitive' with NFC. Moved the cards away from the phone, the problem stopped.
  10. Psjanice99
    Cupcake Apr 12, 2021
    Psjanice99 , Apr 12, 2021 :
    I have the same issues, been happening weeks ago, once in a while it will vibrate itself without any notification. I just cleared all of my apps cache 20 min before this is happened again.
  11. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 13, 2021
    Caomhin , via OnePlus 6T , Apr 13, 2021 :
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    ⚠️This will not delete your apps data but you will have to provide permissions for all your Apps again.⚠️
    Check if this can help.
